Question about Samsung SW62ASP Top Load Washer
My washing machine samsung wa10u3 makes noise
When it starts to rotate, it makes noises as if something is broken.
SOURCE: what does ED mean on a washer machine
DOOR NOT CLOSED PROPERLY OR POSSIBLY DOOR SWITCH PROBLEM.
Posted on Dec 04, 2007
milten1
  • 1304 Answers
SOURCE: samsung washing machine b1245s makes a grinding
i would grab a towel and check the pump for grit
and things that dont belong
may not be the actual problem but thats whered id start
have a great day
Posted on Oct 09, 2009
  • 3 Answers
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
Posted on Aug 16, 2010
  • 17 Answers
SOURCE: Hi my washing machine samsung
because the function of filter is to block the small particles or dirty things including grease or oil etc., before disposing the water, and to avoid the clogging of floor drain and even sewage line. And after you used it you should check the filter if theres a some dirt, and grease or oil to clean up to avoid clogging and unclean water from your washing machine
Posted on Feb 06, 2011
SOURCE: Samsung B1045AV cannot drain
if i do the washing, and it nears the rinsing cycle, it stops and error 5e appears... can I replace the pump myself...
Posted on Feb 21, 2011
Washing machine circuit diagram wa10u3
You have posted this question in the Samsung CARS and I believe you are working on a Laundry Washing Machine. You may want to repost this question in the Appliances Section
Apr 08, 2013 | Cars & Trucks
Uneven rotation of basket, bang noise, water spills
if you can open the door,grab the inner basket at 9 and 3 o'clock and see if you can move it sideways,then again at 6 and 12 o'clock and move it up and down,if you can do this,then the drum spider trunnion is broken in behind the tub and the tub is loose which will require a new tub and trunnion as they are not sold separately at about $400.00
Oct 22, 2012 | Whirlpool GHW9400 Duet Washer
Wash machine model mav 7600, started making tremendous noise, first in spin cycle only and then in wash cycle also. After running a few loads with the noise the machine just stoped running....
This sounds like collapsed/broken drum bearings. Check for movement between inner and outer drum. Also rotating the drum by hand will be hard (or immpossible), and noisy. It could be the motor and belt, but most times it is bearings.
Aug 11, 2010 | Maytag Washing Machines
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washer makes clicking noise when tub rotates
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995522231.pdf here is apart break down of your unit. if you scroll down to pg 10 you see the inner baket assy, chances are youve snapped parts(14)which screw into (15). perhaps you found a broken screwhead inside the tub after laundry was done? id remove the agitator screw down the shaft and it will be quite apparent
Nov 07, 2008 | Frigidaire FEX831CS Top Load Stacked...
Would not dry clothes to original dryness. Now drum is making a whinging noise at the drum spin as though its catching on something every time it rotates. Also made a very loud clattering noise as it...
I had this same problem. The drum spins on two small wheel which with the help of the drum belt support the drum. The wheels or their brackets may be broken and need to be replaced. These are accessable by taking the back off the dryer. Best to take the old/broken ones in to insure you get the exact replacement.
May 01, 2008 | Washing Machines
Samsung washing machine WA71N2
can you hear the pump making any noises,if you can (humming sound)then it may be blocked with lint,coins etc.if the pump isnt making any noises then it may be faulty or a broken wire to the pump or you have a no drain button pressed in . hope this helps
Mar 07, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Samsung J1045 Front Loading Washing Machine Loud Banging Noise
Throw it off a cliff. I have the same model and have had so many problems. Don't even bother calling customer service, they won't help. Cut your losses and buy a new machine
Mar 06, 2008 | Washing Machines
Washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Samsung SW62ASP Top Load Washer Logo
24 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
