Vaillant ecotec f79
Combi boiler with fault code f79 what is it how can it be fixed
  • 55 Answers
SOURCE: lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Posted on Oct 27, 2009
SOURCE: hi i get fault 28 on my vaillant boiler
F-28 is a common error for my vaillant. I have had this problem serviced at least 10 times (all under warranty). It is an ignition problem and can be connected to a number of things. I have had the starter electrodes cleaned only to later have them replaced(4 times). I just had the "panel" replaced yesterday (looks like a motherboard or electronics panel). This is the second time to have this replaced. All of these things can give you an F-28 error message. I have an atmotech pro and have had ongoing F-28 issues for two years. They are looking at venting/air issues as well to see if this is the problem. douglas
Posted on Dec 26, 2009
  • 104 Answers
SOURCE: vaillant eco tec pro 28
IF the weather is extremely cold, and you're getting F28, the external pipework may be blocked with ice. Warm up the external pipes (lag them if you can) - and now see if your boiler will re-ignite.
A friend fixed our condenser boiler with this tip - hope it helps you.
Posted on Jan 09, 2010
  • 36 Answers
SOURCE: hot water only warm no faults showing radiators ok
you need a new dhw thermistor
Posted on Jan 24, 2010
  • 36 Answers
SOURCE: its a vaillant condensing gas boiler, it is
f:28
air in gas
gas rate low
could be gas valve faulty,ignition transformer,ignition cable.
if there is a spark then its your gas valve,if no spark then check continuity on harness and spark generator,also check earth to appliance
Posted on Jan 25, 2010
Got a f.75 on boiler have to put pressure up to 2.0 bar before it starts
I take it this is a Vaillant EcoTec boiler? If your having to pressurise to 2.0 before the F75 goes, there's a strong probability there's a problem with the water pressure sensor. These can sometimes just have dirt/sludge in them, and can be cleaned, however a lot of the time they just need to be replaced. F75 can also mean there's a circulation problem through the boiler, and you will get the same fault code. If you have the old rubber hoses on the flow and return pipes, these can be prone to blocking/restricting and Vaillant have actually modified this part whereby by the pipes are solid copper.
Dec 04, 2012 | KDS Valiant 6380iPTD-01 Notebook
Manual for a Vaillant combi boiler, ecoTEC pro28
my eco tec wall mounted boiler cuts out after about 10to15 days this unit was fitted in august this year
Sep 29, 2010 | Heating & Cooling
Code f28 what isit?
According to the user's guide, the fault code means that the boiler failed to start after 5 attempts. Here is the manual where I got the information. I would confirm the codes with your particular model. I am presuming that the codes would be standard for all their models. Source(s): http://www.vaillant.co.uk/stepone2/data/…
Mar 10, 2010 | Water Heaters
Vaillant Combi boiler
LOOK ON ONE OF THE COVERS 75% OF ALL CODES ARE ON THE INSIDE OF A COVER FOR SERVICE TECHS, NOT MUCH HELP BUT HOPE IT LEADS YOU DOWN THE RIGHT PATH
Jan 23, 2010 | Heating & Cooling
Lost my user manual for the vaillant boiler ecotec plus 824 R1
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Valliant ECOmax boiler is not giving me any hot water
My Valliant Ecotec Pro Combi Boiler (approx 4 years old) does not start up. The fault code showing is F.22. I would be grateful if you could let me know what the problem is and obv how it can be fixed. Thanks and regards, Joanne Byne
Jul 03, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
My parents have a Vaillant Ecotec 831 boiler. Has continually broken down ever since it was fitted nearly 2 years ago. The guy who fitted it keeps coming out and it works for a few days then packs in...
Get vaillant to look at it. It could be installation fault. Their advise is impartial and they can advise if boiler can be repaired.
devinder
Corgi engineer
Oct 14, 2008 | Heating & Cooling
Vaillant Ecotec combi boiler - radiators working but no hot water flow to taps
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Oct 05, 2008 | Heating & Cooling
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
