The keyless remote to my nissan pulsar model N16 series wont work. how can i program it to my car?
SOURCE: 1999 NISSAN ALTIMA KEYLESS REMOTE PROGRAMMING
1999-2003
Enter vehicle, close and lock all doors.
slowly insert and remove key from ignition 6 times within 10 seconds. The tail lamps will flash to indicate original code has been erased. Turn ignition to the ACC position.
Press any button on 1st transmitter.
Hazard lamps will flash to confirm programming.
TO enter additional transmitters, unlock then lock the doors using the power lock switch located on the driver door.
Press any button on additional transmitter (up to 4 tansmitters total possible). Hazard lamps will flash to confirm programming.
open the driver's door.
Turn ignition off.
You must re-program all existing transmitters as this process erases codes from car.
Posted on Jul 08, 2008
SOURCE: nissan murano 2005 sl keyless entry remote programing
Close all vehicle doors, LOCK doors using drivers side switch.
Insert key all the way into the ignition, (do not turn) remove key.
Repeat this step 5 times. (6 total)
Hazards should flash to indicate program mode.
Press any button on transmitter to be programmed, hazards should flash to indicate successfull program.
*For additional remotes, cycle drivers door lock UNLOCK, LOCK, press any button on remote, hazards should flash. Repeat step as necessary.
Ignition ON, (engine off) ignition OFF, UNLOCK using drivers side switch, test remotes.
Source
Posted on Aug 06, 2008
hiseyj
  • 99 Answers
SOURCE: need to program remote keyless entry for 2003 nissan pulsar?
If it is a 2003 model year vehicle follow this procedure. If it doesn't work, you may have the wrong fob which happens all the time.
Sit in vehicle and close all doors.
COMPLETELY insert and remove ignition key more than six times within 10 seconds.
Hazard lights should flash twice.
Turn ignition to ACC position
Press and hold any button on the new key fob hazard lights will flash twice
For a second key fob using the master lock switch, lock and unlock the doors then hold down any button on the second remote until the hazard lamps flash twice.
Then you are done open the door to exit the programming mode.
If the lamps didn't flash when holding down the key fob make sure you have the right key fob, they are different for each car.
Posted on Nov 26, 2008
emissionwiz
  • 78267 Answers
SOURCE: Program keyless remote entry
I need a year, but u can look it up at the link provided below.
http://www.programyourremote.com/
Posted on Nov 28, 2008
emissionwiz
  • 78267 Answers
SOURCE: 2006 chevy equinox keyless remote programming
from the service manual:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Please go to the nearest GM dealer for assistance
Posted on Mar 26, 2009
I'm looking for a stereo harness wiring colour codes for 2003 N16 Nissan Pulsar. Factory stereo model #: 14787210.
try google images for a diagram, there's other models shown but likely the colours are the same
Nov 14, 2016 | Nissan Cars & Trucks
Where is the crankshaft sensor located on the N16 Nissan Pulsar 2003 model?
Its beside the crankshaft look for the wire that goes to the crankshaft thats ur sensor
Apr 26, 2015 | Nissan Cars & Trucks
Problem with Nissan N16 brakes
Master cylinder could be bad and not allow to shift.What year 90 or 03?
Mar 14, 2017 | 1990 Nissan Pulsar
Nissan Pulsar missing while air con is on
please check your vaccum lines for leaks
Nov 10, 2009 | Nissan Pulsar Cars & Trucks
The air con on my 2000 N16 pulsar keeps cutting out...sometimes it works fine but other times the light wont come on on the button and the air doesnt cool when this happens.is it a loose connection?
It could be a loose connection or bad section of the HVAC module, yes. If it checks out I would check the pressure in the high/low side which could be tripping the switches to cut a/c operation.
Aug 29, 2009 | Nissan Pulsar Cars & Trucks
Need to program remote keyless entry for 2003 nissan pulsar?
Nov 25, 2008 | 1990 Nissan Pulsar
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
