Question about LG 50PG60UD 50 in. HD-Ready Plasma TV
When i turn my tv on, you can hear it turn on but then green light flashes eighteen times and then displays constant green light with a black screen
SOURCE: LCD SCREEN WILL NOT TURN ON RED LIGHT FLASHING
what bank in p.a. can i open a checking account thats wont hold it against me if i owe another bank money?
Posted on Oct 04, 2009
  • 8457 Answers
SOURCE: Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 07, 2010
  • 418 Answers
SOURCE: When you turn on the TV the screen flashes through
Sounds like it's in a service burn-in mode. LGs need a service remote to de-activate. Probably easy for a local LG shop.
Posted on May 03, 2010
welcomejee
  • 10594 Answers
SOURCE: My LG 50PC5D has a hard time turning on. when
It seems issue with power supply board and most probably few electrolytic capacitors are dried up and causing problem.
Qualified local tv repairman visual check is needed to confirm the reason of problem as he will test/ check output volts of power supply.
If this tv is 3-4 years old then problem would be in power supply board as mentioned above.
Let me know if you have additional question.
Thanks.
Posted on Sep 26, 2010
  • 13 Answers
SOURCE: Hard time turning on tv. I turn it on, green light flashes a few times then becomes solid green. No picture or sound. I turn it off and light becomes red. I do this at least 5 times before tv will
There are some capacitors on the main boardthat are low quality. You can buy a capacitor repair kit on Ebay that contains a set of capacitors to replace the offending ones - about 15-16 bucks. I soldered in the new capacitors and the TV has worked perfectly since.
Posted on Nov 28, 2011
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
MY SONY LAPTOP WONT BOOT
The flashing amber light means the screen is in power save mode. Since you are not seeing a "No Video Signal" things are looking up.
You want to use the menu buttons on your screen to navigate through and locate the power save time out settings. Its best to set it for 'never'.
If that makes the change a fix, let me know, I'll guide you through the settings on your desktop display to control the display time out.
Regards,
Worldvet
Jul 24, 2008 | Computers & Internet
Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Mar 21, 2007 | Mitsubishi WD-62525 62" Rear Projection...
LG 50PG60UD 50 in. HD-Ready Plasma TV Logo
19 people viewed this question
Computer Repairing
Computer Repairing
