Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westell Versalink 327w
Hi,  I recently had a extremely bad issue with my modem. At first it was working fine, but for the last couple of days, the download rate is extremely, and I mean EXTREMELY slow. I am unable to download files (they seem to stop at around 3% and just time out) I cant watch videos because it seems to stop buffering when it gets to 1/5 of the video. I called Verizon and they tell me that my internet connection is excellent and shows no sign of "weakness". Im not 100% sure if it is the modem, so if theres any suggestions at all, I would greatly appreciate it.
Without knowing more about your system and what all you are running, etc it makes analyzing your problem more difficult. I had a problem with my dsl and it turned out to be a bad connection at the switchboard. Unfortunately it took almost six months and verizon switching two wires around to fix the problem, but I did get some free service... One of the things I did was set up a batch file to ping three locations, (localhost, the IP of my modem, and an external IP), I had the ping command export the data as well as a time date stamp to a text file. I set this up to run every 5 minutes using a freeware scheduler program. It worked great and with this text file, I was able to show the verizon technician, that despite the fact it is working now, it wasn't working 80 percent of the evening...
Hope this helps / gives you ideas.
E.
Posted on Dec 14, 2007
  • 49 Answers
Consider Internet security softwares that might heve been installed on your pC without you knowing it
Posted on Oct 13, 2007
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
Jul 19, 2009 | Westell Wirespeed VersaLink...
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
VPN through Westell Versalink 327w
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
1,950 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
