Question about Yamaha AV-1 System
How to connect the yamaha cinemastation av-1 5.1 to pc
2 Suggested Answers
gokomets
  • 120 Answers
SOURCE: how do i connect my yamaha cx-1 preamplifier to my
Not sure what for but through the tape monitor jacks I think unless you have pre/main jacks. Why another preamp when the receiver already has one?
Posted on Apr 14, 2010
I'm trying to connect a DVR to my Yamaha HTR-4066 receiver, but it appears there's no signal coming from the AV-OUT ports.
You need to connect cables from your TV to the AV input ports on the receiver to get a signal out.
Jul 28, 2017 | Yamaha Televison & Video
How to connect cd player to my Yamaha RX-V733
If the RX-733 is similar to the RX-773 then the Audio 1 and Audio 2 ports are audio inputs on the AV receiver. The AV 5 and AV 6 ports are for composite audio/video connections.
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
How do i connect my yamaha cx-1 preamplifier to my yamaha rx-v3800 av receiver
Apr 14, 2010 | Yamaha RX-V3800 Receiver
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
Jul 05, 2009 | Yamaha EQ-70 Home Equalizer
To connect Asus Notebook to Yamaha RV-502 Av Reciever to play music
Hi, Most notebooks have a 1/8 female plugin from your audio card. (headphone Jack)
Now, you need a cord with a 1/8 male plugin on one end and two RCA Jacks on the other.
All you need to do is connect the cord to (AMP) RCA in and the 1/8 Jack to you notebook.
This will work fine. Good luck
Oct 12, 2008 | Computers & Internet
I have a yamaha av-1 surround sound and can't figure out how to connect it to my tv, i was able to connect my dvd player up but can't get to tv thru the yamaha. My tv is a Hitachi 55VG825 model. thanks
Take a set of phono cables from tv audio out then to a input on yam,set yam to this input ,sound to prologic2 and you shuold be up and away.
hope this helps.
CABLE GUY.
Jun 28, 2008 | Yamaha Audio Players & Recorders
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
DVD player cannot read any DVDs. Says "Region Error"
I Just started getting this same error. All the way down to the "Philips" logo. I wrote to Yamaha to report the problem and all they would (or could) tell me was to take it to any authorized Yamaha repair center (Best Buy). I sure would like to know if you got any resolution to your question in Mar. If not, what did you do?
Mar 18, 2007 | Yamaha DVR-S120 DVD Player
Yamaha AV-1 System Logo
44 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
