Question about Dell Latitude D600 Notebook
1 Solution for "I am out of warranty and the hinge is failing
1 Solution for ''I am out of warranty and the left hinge facing the screen is failing Latitude D620
    Problem Solver:
  • 15 Answers
If you are comfortable taking it apart, get a replacement on ebay.
Posted on May 10, 2009
My frigidaire microwave door is sagging and is about to fall off
You will need new door and hinge replaced
send model # for price quote
May 13, 2015 | Frigidaire PLMV169DC Microwave Oven
When dryer finishes it just keeps on beeping
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Jan 10, 2013 | Haier HDY6-1 Electric Dryer
Can't get the door back on
Instructions
Jan 09, 2013 | Dryers
Hinges are loose on Toshiba NB505N508BL
Turn off the laptop, and remove the cord from the outlet.
Lift the laptop lid so the screen is in an open position.
Locate the small screws in the lower left and right corners of the screen.
If the screws are concealed by plastic plugs, carefully pry them out with a flathead screwdriver.
Use a Phillips screwdriver to turn each screw in a clockwise direction to tighten it.
Move the screen up and down to test it.
If it is still not tight, twist the screws counterclockwise to remove them.
Store the screws in a safe location.
Slip the tip of a knife into the seam where the front and rear of the screen meet.
Lift up on the knife to pry open the cover, and continue until the back cover is removed.
Rotate the laptop so the rear of the screen is facing you.
Locate the screws at the lower left and right corners of the screen.
Twist the screws in a clockwise direction to tighten.
Gently push the back of the screen into place with your fingers until it snaps back on.
Turn the notebook around so the monitor is facing you.
Reattach the screws to the bottom left and right corners of the screen.
Push the plastic plugs back over the screws if your computer had them.
hope this helps
Oct 11, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
Is this a common problem , 1 The plastic frame around my screen has a slight hairline crack FROM the bottom left corner of the screen going out . 2 Is this a concern for the laptop .
That crack means you have a problem in the HiNGE part.
You have to bring that laptap to a tech and have them replace/repair/lubricate both hinges before it breaks the whole LCD screen support and damages the wiring leading to the LCD.
Gently close the LCD part when closing!
Hope that helps!
Nov 13, 2011 | ASUS N53SV-XE1 Laptop
One day my nuvi 245 continues to show "press dot". So I keep pressing dot only for somewhile because after just 1 second from "turning on" touch screen does not work. That means even...
Your touch sensitive screen may have failed. The touch sensitive screen is a thin transparent film that is secured over the front of the display screen.
When it fails, you can no longer select or input anything into the GPS via screen. This of course renders the GPS pretty much useless. Garmin will exchange your defective GPS with a factory refurbished unit with the latest maps and provide a 90 warranty for many GPS units. The Nuvi 250 service cost is $69. I could not find your Nuvi245 model listed so you might want to contact Garmin directly to see what the replacement cost will be.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 09, 2011 | GPS
1. hinge is cracking all the way across. Where to send for repair?(past warranty i Think) 2. veriface does not load logon box anymore?The screen displays and I can see my face-but can't log on. ...
Hi sjctwin1,
1. To fix the hinge issue I recommend to contact lenovo technical support at 877-453-6686 option 2. They will set up a depot repair for you.
2. For the veriface concern, try to uninstall and reinstall the application.
--> you can download the veriface here
Hope it helps,
Thank you for using FixYa
Best regards,
Reyjoshua07
Jan 14, 2011 | Lenovo IdeaPad Y510 Notebook
Hinges are gone
You should be able to order the hinges on ebay.That would be the first place to check.
Jul 07, 2009 | Lenovo IdeaPad Y510 Notebook
My nokia 6085 main and mini display went blue and won't show me anything but I can still call people if I remember their number
I had the same problem and mine was 2 months over the year warranty. I took the outer screen casing off and slightly tapped the connector that connects the screen to the keypad. Voila! I had a screen and now I can at least move my info. The top of casing on the screen pops off near the hinge (there should be a notch). Do this gently and lightly move the black connector on the right side as you're facing the hinge. It may buy you a little more time. We'll see how mine does.
Jun 03, 2009 | Nokia 6085 Cellular Phone
Dell Latitude D600 Notebook Logo
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
