Question about Gateway M-6750 Notebook
Little clip Hi, there is a little clip that keeps coming undone in the motherboard place. This is the second time and it keeps shorting the computers moniter and power out, what the hell.
  • JDTec
    JDTec May 11, 2010
    Where is the clip located?
  • 749 Answers
Is this a clip for holding something in place or a jumper like this one? little clip - 5269983d5c31a7ca
http://www.thg.ru/howto/20020904/print.html link if picture does not show ( scroll halfway down to see jumper photo.
if it looks like this , bend the two pins it goes on apart just a tiny bit before you replace it on the pins, this will add enough tension when you put the jumper on to keep it from freely falling offf
Posted on May 08, 2009
I have a singer ultralock 14u34 - the right needle thread keeps coming undone. anyone have a fix for this??
"Coming undone" What do you mean? Is it breaking while sewing? Is it too short and is slipping back through the needle?
If it's breaking, try changing the needle. If i's slipping back... give it some length when you thread.... and at the end of a seam Run it out... 10 inches before you cut it off close to the fabric. That little bit of thread waste will make you feel much better about your serger.
Sep 29, 2013 | Sewing Machines
Replace bios battery
http://www.asus.com/Motherboard/P5KPLAMPS/
FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE, reaching inside your unplugged from power, computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again, upon your return.
Motherboard installed in computer case, the CMOS battery, (BIOS battery), is located at the Bottom/Right corner; above the four Red SATA connectors.
The CMOS Battery holder has a lock clip on one side.
This clip is eased to the Outside edge, in order to release the CR2032 CMOS Battery. (A type of watch battery)
Suggest use a stiff plastic object to release lock clip.
Most however, use a small Jewelers flat tipped screwdriver.
You want to JUST press on the Lock Clip itself.
The battery should just pop-up a little. Then a fingernail is used to lift that side up, to access the battery.
When reinstalling remember the Positive ( + ) side ALWAYS goes UP.
After locking the new battery in, make sure no cables were accidentally pulled loose.
Also just for ease of mind, try to push the Ram Memory module/s in ('Stick') more. Make sure the Locks on both ends are locked in place.
A lot of times the Ram Memory modules get bumped loose, accidentally.
Close the computer case. Plug computer back into power.
WAIT 1 minute, turn the computer on.
Go to the taskbar at the bottom of the Windows screen, and to the right.
-> Right-click on the Time.
Now reset the Date/Time to what it should be.
Need guidance on that post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | ASUS P5KPL-AM/PS Motherboard
Well i dont know what happened because when i turned on the computer the brightness/contrast kept on going up and down and it doesn't let me exit but when i finally can or at least try it comes back up...
Hi , friends ,
It is moniter problem check the pc in another moniter ,and ensure the moniter either ok or not, then go to nearest technician sole that moniter .
Hope it will solve you.
Dec 17, 2010 | Computers & Internet
NO VIDEO COMES TO THE MONITER, THE MONITER WORKS WITH OTHER COMPUTERS, ICHANGED THE VIDEO CARD AND STILL NO RESULTS , ALSO THERE IS A LONG BEEPING NOISES THREE TO FOUR TIMES AS I TURN THE POWER BUTTON ON...
It sounds as if your on-board graphics has stopped working. If you have a graphics card to try installing it. That may solve your problem. If not you will have to contact Dell about a motherboard replacement. the last time I looked at a Dell XPS system you can't install a retail motherboard in it.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
Still will not boot
5~6 seconds of real time OR your estimate? perhaps you need to be more patient and let the motherboard current drain out sufficiently before trying to POST...
10 minutes is overkill I know but go off and do something else and then come back, a watched pot never boils eh?
Feb 14, 2009 | Asrock K7S41GX Motherboard
Canoscan lide 60 drive cord problem
Drive cable is attached in two places. One at the hinge end of the scanner. The other at the control panel end. The hinge end connection is a simple ball-end that slips into the slot. The control end fixing is more complicated. The wire cable at this end has a spring attached. This is fixed to a plastic fitting which clips into place. Look carefully the plastic fitting. Fit the spring over the small peg and take the cable round the radiused part of the plastic fitting. And refit the plastic clip to the scanner body.
c21b280.jpgFiddlly but doable.
The cable often comes loose when someone investigates how to take the scanner to pieces. Underneath they see a round pin with a small rectangle on each side. They press the round pin in slide the piece of plastic in the rectangle and hey presto they'll undone the cable. Oooops!!!!!!!!
Mar 13, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Tyan motherboard
No replacement is available, and none is needed, the RAM should work without it. Just make sure you push in the RAM all the way, so it's properly seated; usually, the clip will pop into the notch on its own, when its fully seated. If the RAM isn't in all the way, the computer wont recognize it, or may not boot up. There's a few exceptions, when the clip is needed to hold the RAM down, e.g. in laptops and certain server motherboards, where the RAM folds in against the motherboard.
Oct 01, 2007 | Tyan Thunder K8W (S2885) (S2885ANRFKIT2)...
Thread keeps coming unthreaded in the machine
the green thread needs to go under the brown thread between the clip and the brown needle. I had this problem too.
Mar 18, 2006 | Kenmore 16622 Mechanical Sewing Machine
Open Questions:
Gateway M-6750 Notebook Logo
142 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
