Question about Gaggia Accademia Espresso Machine with 3 Free Coffee Boxes and More
Gaggia Accademia Espresso leaking water - Gaggia Accademia Espresso Machine with 3 Free Coffee Boxes and More
  • 2039 Answers
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Posted on Feb 03, 2008
SOURCE: Fill Water Tank But Water Tank is Full
As suggested previously by pierre235, the solution is really simple: make sure that the float in the tank really does float when water is full. Here it is exactly how...>>...fill the tank slowly (as it is still unattached to the machine) ensuring that the float does float and then slowly put/attach the tank back with the machine - keep checking the display for status. Then, if it's OK, fill the rest of the tank until it's full. Then restart the machine - voi la .. all works.
Posted on Mar 25, 2008
EsWorld
  • 1618 Answers
SOURCE: espresso gaggia titanium. Water Tank leaking
The o-ring on the bottom of the water tank is either missing or not seated properly.
Posted on May 11, 2009
SOURCE: gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Posted on Aug 14, 2009
SOURCE: low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Posted on Sep 28, 2009
Gaggia cappuccino xtwo. What is error code 1?
Im not sure if this will help but I've got some Gaggia Accademia Error Codes, maybe they are the same as the Gaggia cappuccino xtwo.
Hope it helps. https://wll-documents.s3.amazonaws.com/Gaggia/Accademia/Accademia%20Error%20Codes.pdf
Apr 05, 2016 | Gaggia Coffee Makers & Espresso Machines
Gaggia accademia
Most likely a connecting pipe might have come loose or leaked, boiler leaking might also be possible
Jul 17, 2014 | Gaggia Coffee Makers & Espresso Machines
'Water circuit priming'
and your solution to this problem was????
Mar 15, 2014 | Gaggia Accademia Espresso Machine
Can an owner of a gaggia academia get a repair manual for it. i need to get into mine and see why its leeking
You can buy one from america. http://www.shop.partsguru.com/Gaggia-Accademia-SUP038G-Service-Manual-SUP038G-Service-manual.htm Ive got a problem with mine too and thats the only one i found so far
Jul 23, 2013 | Gaggia Espresso Machine Academia Model...
Empty drip tray message
On the bottom of the machine attached to the drip tray is a sensor that "sees" liquid. If there is no liquid thgere, clean the sensor, if there is, empty the tray!
Jan 01, 2013 | Gaggia 1003380 Accademia Espresso Machine
My new accademia gaggia won't work, error code 05
see this causes and fix it. God bless you
Reset the code read your instr. manual
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord, the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 1003380 Accademia Espresso Machine
My new gaggia accademia won't work. IT shows error code 05. Con Youtube help me?
reset the error code and read your instr. manual. God bless you
proceed according.
If the coffee maker doesn't work at all, make sure power is on at the outlet, check the electric cord , the internal fuse or the thermostat and heating elements replace as needed.
Oct 17, 2012 | Gaggia 10003380 Accademia Automatic...
Gaggia Accademia Espresso Machine with 3 Free Coffee Boxes and More Logo
167 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
