Question about Bakers Pride EB-2-2828-S 2083 - 28-in Countertop Deck Oven, Steam Inje
Buzzing sound When we turn the dial to active the heating element on the bottom of the top oven - a buzzing sound comes from the side of the panel inside the oven. Everything else functions normally - just turning this knob from zero makes the noise. Ay ideas?
    New Friend:
  • 5 Answers
Maybe the knob might be a bit rusty, or it's always like that. It's also a good idea to get people to check the knob.
Posted on Nov 28, 2013
Early 1960's Frigidaire 24" Double wall oven not heating
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Nov 07, 2014 | Ovens
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
I have a whirlpool range mod rf368lxpq o replaed probe and panel still very slow to come to temp. pre heat goes to about 200 deg and then veryy slow to come up to temp and hold temp
It sounds like one of the elements are not working. There should be a concealed element in the bottom of the oven and a 'bake assist' element at the top iether seperate from the grill element or as a dual element assembly. Both of these elements should heat on bake function (not the grill element though), check for heat from both by turning bake on and feeling for heat from top and bottom. The oven requires heat from bot to get up to and maintain temp.
Hope this helps
Dec 02, 2009 | Kitchen Ranges
I was roasting a chicken in my Maytag Cooktop when I heard a loud buzzing and a "pop", all of the power in my house went out. Something had tripped the breaker. My husband reset the breaker but my stove...
there is a short for sure, sometimes when the heating element burns out and melts, it touches the metal inside the housing causing a short. inspect the heating elements in the oven(top and bottom). the loud buzzing sound is what a shorting out heating element makes as it melts like a weldin rod, usually because of using tin foil(not recommended)
Jun 15, 2009 | Maytag MEC5430BDS Electric Cooktop
Ice is forming around fan in back of freezer compartment
The defrost system is not doing it's job. I bet if you took the panel off below the fan you will see more ice on the cooling coils. There should be a light coat of frost on the coils but not a heavy ice build up. There is a heating element at the bottom area of these coils which should be defrosting all this ice.
1. A defrost timer turns this heating element on.
2. The heating element melts the ice.
3. A thermo disc attached to the coils will turn the heater off.
One or more of these are not doing it's job.
Dec 16, 2008 | Frigidaire Refrigerators
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Mar 07, 2008 | Microwave Ovens
Loud buzzing after heating up
the buzzing is normal.  there is an element inside the quartz tube much like a filament in a light bulb.  as this heats up it starts to move.  where you have electrical energy you also have magnetism produced. metal objects vibrate when they are in or within a magnetic field. the element is tungsten wire and vibrates off this magnetic field.
Oct 13, 2007 | Marvin Quartz Radiant Heater
Bakers Pride EB-2-2828-S 2083 - 28-in Countertop Deck Oven, Steam Inje Logo
726 people viewed this question
Top Bakers Pride Cooking Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Bakers Pride Cooking Expert? Answer questions, earn points and help others
