Question about Dell HQRP Replacement Laptop AC Adapter
Can some one tell me how to fix my ac adapter VGPAC19V19
MY LAPTOP AC VGPAC19V19 CHARGER DOSENT LIGHT UP AND IT MAKES A WIERD BEEPING noise i need a solution to fix this
  • i know you can do that and thanks for telling me but is there a simpler way to fix it
I have the same problem with my adapter. what i do is i wiggle the supply cable(the one going to the laptop, at the base near the box) until it stops beeping. it usually takes about 3-5 mins. After it stops blinking i try not not to move it at all. Don't even look at it.
Posted on Sep 19, 2009
I had a smilar problem: adapter got hot, LED would go off, When AC power cord was removed and re-inserted, the adapter gave pulsating "beeps" every 0,5-1 seconds.
Sometimes this could be solved by twidling the DC cord close to the adapter.
After opening the adapter and inspecting the cord, one of the leads showed continuous sparking.
Removing some 3 inches of the leads and resoldering them to the board fixed the problem
Cheers
Kees
Posted on Jul 30, 2009
  • 51 Answers
You should contact your services center, because opening charger without enough knowledge is not an suggestion
Posted on May 10, 2009
  • Hari Saryono
    Hari Saryono May 11, 2009
    there's no other way except opening charger case. This will break the seal. The equipment inside is a package, so it's rather difficult to fix it per part (usually, the technician will change block of parts, which is more expensive than buying a new one). I guess, some transformator not working well .
    I'm afraid if you let this condition for a long time, your laptop will be broken because of unstable power supply
    Problem Solver:
  • 5 Answers
Sony has a recall on some of these adaptors. See if yours is one of them. https://esupport.sony.com/perl/compatibility.pl?comp_project_id=14
Posted on Nov 18, 2009
Toro ccr3650 wont start
Did you mean the AC adapter/battery charger made a loud noise? It means the ac adapter is bad and you need to buy a good working ac adapter.
Feb 11, 2014 | Sony VAIO VGN-FS690P Notebook
Ac adapter beeping
There are a few things you may check why the laptop charger keeps beeping. Click the following link to get details:
http://www.chargerbuy.com/blog/laptop-charger-beeping/
Oct 25, 2012 | Dell Alienware Computers & Internet
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
Asus netbook ac power cord adapter stopped working...no blue light on...not charging computer...what to do and need new one?
You need a replacement AC adapter, it's very cheap online.
1)Output Voltage is within +/- 5% of your old charger's output.
2) Output Current is the same or higher than that of your old charger.
3) Connector tip must fit securely into your laptop.
Jul 15, 2010 | ASUS AC Adapter- Universal Notebook AC...
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
I have a Toshiba Satellite laptop and it's about 10 years old. That's why I need to plug in to my ac adapter in order to turn it on. But now, even when I have the ac adapter plugged with my laptop, the...
sounds like charger is gone , can you hear a humming noise from your charger when you press it againts your ear, if so it seems ok if not its gone, you can search ebay for a charger and they are very cheap.
hope this helps
Dec 04, 2009 | Toshiba Satellite A105 Notebook
The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Mar 15, 2009 | Toshiba Portege R100 Notebook
Packard Bell
Check out the following link:
http://support.packardbell.com/uk/item/index.php?i=topic_02437&pi=platform_storeandsave3500&dhepn=C050890000
It includes the following:
Beeping noise and flashing LED
dot.gif dot.gif Situation dot.gifWhen I turn on the Store & Save, it makes a beeping noise and the LED flashes continuously. dot.gif Details dot.gifThese symptoms indicate that the AC adapter is not providing enough power. dot.gif Solution dot.gifThe AC adapter will need to be replaced. I hope this helps, Bob
Mar 24, 2008 | Computers & Internet
AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Sep 12, 2005 | HP Jornada 548 Pocket PC
Dell HQRP Replacement Laptop AC Adapter Logo
1,473 people viewed this question
Alun Cox
