Question about MSI L1350430US Netbook
How to turn off the sleep mode of my - MSI L1350430US Netbook
I cant get the sleep mode off
Step 1: Wear your Fitbit Flex once you are ready to go to bed. Once you're ready to sleep, tap your Fitbit Flex rapidly for one or two seconds. The Flex should vibrate and show two dimming lights to indicate that you are in sleep mode.
Step 2: Remember that while the Flex is in sleep mode, it will not display your goal progress if you double tap it. Instead, the lights will alternate to indicate that it is in sleep mode.
Step 3: When you wake up, tap the Fitbit Flex again for one to two seconds to exit sleep mode. When you access your dashboard, you should be able to see your sleep pattern.
When you are viewing your dashboard, you can adjust your sleep mode setting between "normal" and "sensitive" modes. The normal mode shows you your basic sleep pattern, while the sensitive mode shows more details. Make sure you sync your tracker after you make these changes so that the Fitbit Flex can start recording in its new mode that same night.
Follow step 3 to disable sleep mode.
Jun 09, 2015 | Fitbit Flex Wireless Activity & Sleep...
My LG optimus keeps getting stuck in sleep mode. When I turn it on it seems fine but once it enters sleep mode it won't turn back on. I have to restart the phone to get a picture again. Any tips?
Is it ''sleep'' mode or ''Hibernate'' mode? If ''Hibernate'', then that is the problem. Turn off ''hibernate.'' If it is in fact just ''sleep'' mode, check to see if it is set for ''enter password to exit sleep'' _and_ you don't have a password set up... then either create a password or set it so that it does not require a password upon exiting sleep. Also, you can always resort to resetting everything to ''default'' settings. (This will not effect any data on the phone, and you can take your time setting all the settings ''just right'').
Jan 02, 2015 | LG Cell Phones
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
Sleep mode is blinking. i cannot restart
Have you tried holding the power button for a few seconds till it restart. If that does not work try removing the battery. Once you get it started go to power options and turn off sleep mode and hybrid sleep under advanced settings.
Thanks for using FixYa
Jun 30, 2011 | MSI Computers & Internet
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Dec 11, 2009 | Computers & Internet
My machine is also set to sleep mode and cannot rcv. faxes!
Sleep mode does not affect the reception of faxe check receive settings instead
Aug 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Emachine sleep mode
Try going into your cmos settings at system boot (usually hitting delete or F keys, funtion keys as your computer first turns on). Check to to see the boot sequence and look for sleep mode settings. If there isnt an option there, boot your system in safe mode and check through your windows settings for sleep mode settings.
Dec 18, 2008 | E-Machines emachines (emachinees) CD-ROM...
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Will the camera automatically enter Sleep mode or turn off?
The camera enters Sleep mode over a certain amount of time when not being operated. You can select the time to enter the Sleep mode from OFF, 1, 3, 5 or 10 minutes.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
MSI L1350430US Netbook Logo
20 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
