Question about EliteGroup P4M800PRO-M478 Motherboard
Hook ups hooks up what goes where
  • Mar_kit Jan 01, 2008
    power connections
  • Anonymous Aug 31, 2008
    i do not know how to connect the USB 3 and USB 4 terminals in the pc board. the terminals have 2 sets of wires:
    red (VCC), green (+D), white( -D) and black (ground);
    the slots has 9 pins each
    I want to know which is which???
    Scholar:
  • 116 Answers
Lol wow ;)
Lets assume you have all the right componets.
To make your pc work you need x things
Power Supply 24pin
Power Supply 4pin  (same powersupply, should have this connector to)
Memory
DDR or DDR2 memory (You cannot use both)
Video Card (that board does have integrated video)
Hard Drive (SATA or IDE both can be used)
So all you need to do is connect your PSU to the main board. Make sure their is not 4 missing pins, if so then you only have a 20pin PSU.
Next plug in your Ram. Remember you cannot use DDR2 and DDR at the same time.
Insert your Processor, make sure your processor and socket are alighted to the arrow you will find in the corner of each. Do not FORCE a socket processor.
After that you need to install the heat sink. It looks like yours will most likely have the pain in the butt be careful not to 'get it on the edge" If you dont get the brackets on solid, when you try to connect the other side it will snap off the first side.
Here is the confusing part. You need to connect the case headers. You may or may not have usb connectors. With some luck you will have the type that are all together. Those will only plug in 1 way.
As for your speaker, HDD Led, PWR Led, PWR Switch, and RES Switch, you need to read the board header, or refer to the manual. I have included the link to the manual to help.
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=3061&areaid=2&LanID=0
Posted on Oct 11, 2007
  • 101 Answers
Http://www.dealtime.com/xPF-Elitegroup-ECS-P4M800PRO-M478-Via-Socket-478-MicroATX-Motherboard-Audio-Video-AGP-8x-10-100-Ethernet-LA
or read the manual that comes with it.
Ram goes in the two blue slots, sound & modem in white PCI slots, video in orange AGP slot.  You can't put cards in the wrong slots.
SOURCE:
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
I cant find where to hook up the ground wire there are three batt. hook ups on it not sure why! does it hook to the frame ? and is it the long one or short one ?
Usually the long heavy cable goes from the negative post to the engine, and the smaller ground wire goes to the body or frame.
Mar 02, 2013 | 1994 Mazda 626
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
Apr 13, 2011 | MTX Car Audio & Video
When I turn on my CF-29 it goes straight to a
Have you tried hooking up an external monitor? If you hook it up and see video on that it's a screen issue. If you hook it up and it does the same white thing it's bad video on the motherboard.
May 04, 2010 | Panasonic Toughbook CF-29 Notebook
Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Apr 19, 2009 | GPS
I want to hook up my canon scanner 60 lide
Rectangle end goes to the CPU and the semi-hexagonal shape end goes to the scanner and than install drivers for the same and scanner is ready to use.
Jan 19, 2009 | Canon CanoScan LiDE 60
Equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Aug 27, 2007 | Spectrum Technical Hifi EQ-B5100...
EliteGroup P4M800PRO-M478 Motherboard Logo
192 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
