Question about Kitchen Ranges
Minimum height - Kitchen Ranges
  • Kitchen Ranges Master
  • 2,113 Answers
Many range hood manufacturers recommend 30" to 36" above the range though one site says as low as 24 inches
Posted on Nov 28, 2013
Citreon c5 ground clearance stayed on minimum height, not responding to ground clearance adjustments, but the clearance position displays the corresponding height whenever it is selected without actual...
Sorry to say when my C5 went onto its "haunches" it cost me 700 euros for a new hydrolic pump. Might have been a con though but I have no problem since. It was in Italy.
Sep 20, 2013 | 2003 Citroen C5
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
What is the toe adjustment for a 1998 ford windstar 3.8L
Hello Snsimpson
Here are all the specs for the Windstar.
FRONT ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal -0.25°
Minimum -0.75°
Maximum +0.25°
Split 0.0°±0.5° Caster
Right
Nominal +3.80°
Minimum +3.05°
Maximum +4.55°
Split -0.5°±0.5° Left
Nominal +3.30°
Minimum +2.55°
Maximum +4.05°
Split -0.5°±0.5° Total Toe [1]
Nominal -0.10°
Minimum -0.40°
Maximum +0.20° Clear Vision [2]
Nominal -0.2°
Minimum -2.8°
Maximum 3.2° REAR ALIGNMENT (CURB HEIGHT WITH 1/2 TANK OF FUEL)
Camber
Nominal 0.0°
Minimum -0.3°
Maximum +0.3° Total Toe [1]
Nominal -0.06°
Minimum -0.40°
Maximum +0.28° [1] Positive value specifications for toe-in, negative value specification for toe is toe-out. [2] Negative value specification for clear vision is counterclockwise.
Nov 16, 2010 | 1998 Ford Windstar
I have ''syphoning '' how do I extend my drain hose.
you can try looping and securing the hose up in the back of the machine higher than the height of the highest water level in the tub. you should have enough hose to do this.
May 28, 2010 | Kenmore Washing Machines
I've bought a new cooker hood that filters the air and then re-circulates it. At what minimum height from the ceiling should it be fitted?
Its not the ceiling height that matters its the height above the cooker or hob thats important. Above a gas burner the bottom of the hood should be at least 750mm, above electric burner 650mm . This measurement should be taken from the highest point of the cooker top.
Nov 24, 2009 | Kitchen Ranges
Need to adjust height of handlebar on a jeep sahara bicycle
Most bikes use an allen key to adjust the height of the handle bars. Typically 6mm. But be careful most bikes do not have much adjustment that can be done to the height of the handle bars. The handle bar stem will have a line on it of the "minimum insertion". That line must be below the top of the head set nut for safety reasons. Look for the line as you adjust the height.
Oct 03, 2009 | Jeep Cycling
My whirlpool washer Type 111, will not fill with water. It just drains and not hold the water to begin the wash cycle.
Is your drain at the proper height? I will attach a photo showing the minimum drain height requirements. Have you moved or changed the location of the washer lately? If not let me know so that I may consider another cause. Thanks and I hope this helps. Best wishes.
Sep 01, 2009 | Washing Machines
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
1990 Oldsmobile Ninety-Eight Regency compressor runs when car is off.
The compressor you refer to is the air suspension compressor. It provides air to adjust the ride height of the vehicle. If you will notice by looking underneath the rear of the vehicle you will notice air adjustable rear shocks, or struts. They have plastic tubing plumbed to the compressor under the hood. There is a ride height sensor for the rear of the vehicle attached from the chasis to the rear differential. Whenever the height of the rear of the car is below the threshold setting of the sensor, the system activates a relay and turns on the compressor to raise the rear of the vehicle above the minimum height specified by the manufacturer. As the vehicle ages the air envelopes of the struts loses structural integrity and seepage, or leakage develops. Some depletion of air is normal, but the compressor power supply is independent of the key position, so the compressor can run, and will run anytime the height falls below the minimum. If the car sets unattended for several days, (or weeks) the compressor can run the battery down while maintaining the minimum height. If the system leaks too much air the compressor can burn-out trying to replenish the system. If you notice the compressor runing for an extended period of time, or running too frequently you should have the system checked for the source of the leakage. (Or you can do it yourself with soapy water and a spray bottle by soaking the air bellows on the shocks or struts, and all the lines and fittings from the shocks to the compressor) If you intend to work underneath a vehicle, service stands are mandatory! DO NOT UNDER ANY CIRCUMSTANCES ATTEMPT UNDER VEHICLE SERVICE WITHOUT PROPER SERVICE STANDS IN PLACE AND STABILITY VERIFIED WITH APPROPRIATE FORCE TO PROVE THE VEHICLE CANNOT BE KNOCKED-OFF THE SERVICE STANDS!
Nov 01, 2008 | 1992 Oldsmobile Ninety Eight Regency
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
