I NEED THE SCHEMATIC FOR MY RCA MODEL RLC1906 19"NTSC LCD TV
I NEED A SCHEMATIC
3 Suggested Answers
SOURCE: Need a remote code for the tv 37" Sabre LCD Tv Model # lct371bka. RCA Universal remote Model # RCR660
as soon as u bought the universal remote it came with a paper that say a bunch of codes find ur tv model go to set up look were u can put in the code and follow the code exact
Posted on May 24, 2009
SOURCE: Multisys. TV NTSC tuner to PAL conversion, Brand LG,
i am using a mini multisystem modulator i fixed inside the tv.i used the s-video input of the tv to connect the output of modulator i.e AV -OUT.it works via remote sensor of d mdlt positioned at the IR of the tv.
Posted on Sep 08, 2010
RCA 32 led TR3201A can only get picture in the component setting and only in black & white
Are you in a country that has the PAL Television system and using a TV that is NTSC? That will cause the picture to be in black and white. Your TV is an NTSC model only.
Feb 08, 2017 | RCA Televison & Video
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
Dec 26, 2015 | RCA Televison & Video
Is the Rca true flat digital
I'd need the model number to tell if the RCA TV has a digital (ATSC) or analog (NTSC) tuner. The mandate for inclusion of the ATSC tuner depended on the size of the TV and the year of manufacture. Small (<25" diagonal) TVs didn't need to have an ATSC tuner when they were built until 2007. The older TVs could still be sold with a "cable-ready" or similar NTSC only label. (The 32"+ TVs had to have the ATSC tuners in 2005 and the mid-size TVs had to have the digital tuners in 2006.)
For example the 27F530T was manufactured in 2003 and only has a NTSC tuner. However, the 20F424T was manufactured in 2008 and does have an ATSC tuner.
I hope this helps.
Aug 07, 2015 | RCA Televison & Video
I want schematic for bn44-00469b
Hi. Just google and you will get it. https://www.google.com/search?q=schematic+for+bn44-00469b&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwifxt2kla_QAhXIOI8KHVb3AcgQsAQIGw&biw=1280&bih
Mar 02, 2014 | Samsung LA40D503F7R 40 Full HD 1080P...
Can you give me technical specs for LCD TV TH-L32E3A. Thanks
The proof copy of the Owner's manual includes the specs for the TH-L32EA and is available from: http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation . Enter the model number under keywords and then click search (do not use the drop down menus).
Specifications
Power
Power rating AC 220 - 240 V, 50 / 60 Hz 0.33 A
Normal (Home) mode 42 W
Standby condition 0.2 W
Display
panel
Aspect Ratio 16:9
Visible screen size 80 cm (diagonal)
698 mm (W) × 393 mm (H)
Number of pixels 2,073,600 (1,920 (W) × 1,080 (H))
Sound
Speaker 160 mm × 42 mm × 2, 8 Ohms
Audio Output 20 W (10 W + 10 W )
Headphones M3 (3.5 mm) stereo mini Jack × 1
PC signals
VGA, SVGA, WVGA, XGA
SXGA, WXGA ······ (compressed)
Horizontal scanning frequency 31 - 69 kHz
Vertical scanning frequency 59 - 86 Hz
Receiving Systems /
Band name
PAL B/G Reception of Off air broadcasts
Digital TV 7 MHz VHF / UHF (Australia) free-to-air TV broadcast reception
PAL 60 Hz
M.NTSC
NTSC
Playback of NTSC tape from some PAL Video recorders (VCR)
Playback from M. NTSC Video recorders (VCR)
Playback from NTSC Video recorders (VCR)
Aerial - Rear Standard Belling & Lee connector
Operating Conditions Temperature : 0 °C - 35 °C
Humidity : 20 % - 80 % RH (non-condensing)
Connection Terminals
AV1
Input
AUDIO L - R RCA PIN Type × 2 0.5 V[rms]
VIDEO RCA PIN Type × 1 1.0 V[p-p] (75 Ohms)
COMPONENT Y 1.0 V[p-p] (including synchronisation)
PB/CB, PR/CR ±0.35 V[p-p]
AV2
Input
AV3
Input
Audio
Output AUDIO L - R RCA PIN Type × 2 0.5 V[rms] (high impedance)
Others
HDMI1 - 3
Input TYPE A Connectors • This TV supports "HDAVI control 5" function.
PC Input HIGH-DENSITY D-SUB 15PIN R / G / B: 0.7 V[p-p] (75 Ohms)
HD / VD: TTL Level 2.0 - 5.0 V[p-p] (high impedance)
DIGITAL
AUDIO OUT PCM / Dolby Digital, Fiber optic
Card slot SD Card slot × 1
USB 1/2 USB 2.0 TYPE A Connectors DC 5 V, Max. 500 mA
ETHERNET 10BASE-T / 100BASE-TX
Dimensions (W × H × D) 769 mm × 514 mm × 207 mm (With Pedestal)
769 mm × 480 mm × 75 mm (TV only)
Mass 11.0 k Net (With Pedestal)
9.5 k Net (TV only)
(See page 73 of the manual for the specs as a table - I used Proof 2)
I hope this helps.
Apr 20, 2011 | Panasonic Kitchen Appliances - Others
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Sir I live in Pakistan where tv system is PAL and my HDTv is 17MD is on NTSC so please guide me how I can watch Pal ...
only on rca input not the tuner ,if on rca doesn't work there is a small converter pal to ntsc you can buy on ebay 15 $ it will convert but from rca input it should be fine
Oct 17, 2010 | Philips 17MD250V 17.1 in. LCD TV/DVD Combo
Problem for Sylvania LC195SLX LCD TV Channels will not program in tv.check with different tv it works
It looks like your TV doesn't have a digital tuner in it. Without that you won't be able to receive any broadcast television stations. The spec sheet is here: LC195SLX the tuner is listed as just ATSC/NTSC - not digital. You will need a cable or satellite box to receive stations.
Jun 14, 2010 | Sylvania LC195SLX LCD TV
I HAVE A 2004 RCA MODEL 24V511T. dO i NEED A DIGITAL TUNER IN ORDER TO FOR IT TO WORK AFTER FEBRUARY 17?
Model has one NTSC RF and two NTSC composite inputs. It's compatible with analog Over The Air and non-scrambled analog cable broadcasts. After the US analog cutoff (currently scheduled for June 12) it WILL require a digital to analog converter to receive ATSC digital TV transmisions.
Jan 18, 2009 | RCA 24V511T 24" TV
Rca g26261tn colortrak television
If the TV is HD then yes it is ATSC if it is HD ready Then it is NTSC if it is noe of the above then it is NTSC. The Advanced television standards committiee was developed in 1982 .
Mar 08, 2008 | RCA F32665 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
