6x61011bed An error code 6x61011bed appeared on my hp photosmart plus b210a
  • 17 Answers
SOURCE: Printer HP Photosmart 2610 all-in-one
I found this link, which i think may help you out.
http://en.allexperts.com/q/Printers-1512/error-message-HP-printer.htm
Copy&paste it in a browser!
Posted on May 30, 2008
  • 90 Answers
SOURCE: HP Photosmart C4480 installation error 1935
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01600633&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
This link will take you the the HP website and has a lot of directions that are specific to your problem.  I hope this helps.
Posted on Dec 11, 2008
SOURCE: hp photosmart error code 0xc05d2381. does this
french oeioe
Posted on Aug 16, 2009
luciana44
  • 292 Answers
SOURCE: HP photosmart D7160, ink sys failuar error code:
Hi otissr
If you are lucky, the solution given by HP in the following link will help.
Hope you wouldn't require a service call.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01936219&cc=us&lc=en&dlc=en&product=1156652
Good luck
If my answer is helpful, please give a rating.
luciana44
Posted on Dec 28, 2009
chiplevel
  • 656 Answers
SOURCE: my new HP photosmart B210a
Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.)
Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible."
If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer
Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
If you have a laser printer, inspect the printer's paper rollers. They should be smooth but not shiny. Rollers that are cracked or glazed are a frequent cause of paper jams and should be replaced by a technician.
If you have a laser printer, try cleaning the printer's paper rollers with a lint-free cloth and isopropyl alcohol
Try changing the toner or ink cartridge.
If you hear a clinking sound during printing, your printer probably has a broken gear and needs to be serviced by a technician.
Posted on Mar 08, 2011
Invitations printing off center
You need to ensure that you are setting the program and driver for the correct size of paper. The paper does not need to be centered, the software just needs to start printing in the right place.
Sep 24, 2016 | HP HEW CN217A PHOTOSMART PLUS B210A...
When printing with new ink cartridges the colors seem to line with different striped colors other than what is on the screen.
You may need to perform a align cartridges if you still face the same problem then you might need to do head clean by putting the cartridge heads in warm water for like 5 minuts and then put them back hopefully this shall solve your problem.
Oct 02, 2013 | HP B210a CN216A Photosmart Plus All-in-One...
HP photosmart B210 wont print black
Seems to be a common problem - I had it too. I spent a lot of time looking, but never quite found a consistent fix. I fixed mine in a few steps: First, I removed all the cartridges, and cleaned the filters on the top of the printhead (these are the little screens you see when you look at the tray with the cartridges removed). To do this I blotted each screen with premoistened alcohol wipes, changing wipes frequently, until the wipes were clean. I then removed the printhead by lifting the black handle on the right side, and lifting the printhead straight up. I used alcohol pads on the rear contacts (refer to HP's instructions for changing printheads) in a downward motion only. Finally, I cleaned
Nov 10, 2012 | HP Photosmart Plus B210A Multifunction...
HP Photosmart B210a doesn't support manual duplex printing
Hi Marc,
Use the B110 print driver found at http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=au&destPage=document&dlc=en&jumpid=reg_r1002_usen_c-001_title_r0002&lc=en&product=4022343&.
It is terrible that HP can release a product with such a useless print driver.
Andrew
Dec 31, 2011 | Office Equipment & Supplies
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    49 people viewed this question
    k24674
    jasbo
    jasbo
