2001atra auto hard to start
Have to wind motor over a dozen times or so before it fires up then it will not rev up revs up to a point then cuts in and out
  • 2,113 Answers
It sounds to me either that your vacuum system has a leak or bad part or you need to replace the ecu
Posted on Nov 28, 2013
  • mikadot
    mikadot Nov 28, 2013
    could also be the distributor cap and rotor
My 1999 mazda 323 1.4 cuts out at around 3000 revs and when put revs up its fine
It could be the starter motor cutting out at that point before the main motor comes on. When it is fine listen for two motors going at the same time. If that is happening the starter motor has not cut out when it should, and the car needs a mechanic, or auto electrician to fix it.
Aug 05, 2014 | Mazda 323 Cars & Trucks
How to set the high and low
Turn mixture screws completely in gently, then wind out 11/2 turns each. The saw will be able to start and run at this point. On idle wind Low clockwise till motor starts to die then anti-clockwise 3/4 turn.
High speed is a little more difficult, On full revs wind clockwise till saw starts to rev out (lean Mixture) then back till the sound starts to bubble.
Jul 26, 2014 | Husqvarna Garden
2001 astra auto hard to start and very little power
Could be catalytic converter,did you had any problem with plugs,wires or coils.
Nov 28, 2013 | Cars & Trucks
2001 astra auto hard to start and in lymp mode
This is a dealer computer reset problem or fuel filter blocked
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
1990 lincoln town car 5.0, hard to start then
air idle control motor probably sticking remove motor and spray w-d-40 inside then reinstall and tap with a hammer while running
Dec 07, 2009 | 1990 Lincoln Town Car
1990 daihatsu applause 101a 1.6lt 5spd manual
I have had the same problem, replaced everything. Have not solved it. Sometimes car stops completely whilst driving. Your problrm will only happen when air con is on. There is a small electronic box under glove box. Turn small dial to the low postition or high, whichever fixes it and also bring your revs up with the idle screw on throttle body. I still have not solved my engine cut out problem, must be a faulty relay. I have replaced the computer and distributor but still have the problem
Aug 19, 2009 | 1992 Daihatsu Charade
Back-fires and cuts off
check the distributor to make sure that the rotor is pointing at the no. 1 cylinder when that cylinder is at top dead center on the compression stroke. It sounds like your distributor rotor is 180 degrees out of time. The engine will run but will do what yours is doing.
Jan 30, 2009 | 1987 Toyota Corolla 2 Door
Computers & Internet Logo
David Payne
David Payne
