Gateway zx4951 it failed too start its satus is ooxcooooooe
  • 21 Answers
Try this:
Restore Point:
Try tapping F8 at startup, and from the list of startup selections, select Safe Mode by using UP Arrow Key to go there > then hit Enter.
Try a System Restore once there, to pick a Restore Point before your problem..
Click Start > Programs > Accessories > System Tools > System Restore > pick a different time > Next > etc
If Restore does not work and you do not have a Microsoft Vista DVD, make a Bootable Repair Disk to do a Startup Repair:
Download the ISO file at the supplied link, and make a Bootable Startup Repair Disk from it.
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu.
When you have changed that, insert that Bootable Disk you have made in the Drive, and reboot.
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Above link shows what the process looks like, and a how-to, as it loads to the Repair Options.
Neosmart contains the contents of the Windows Vista DVD\'s "recovery center," as we\'ve come to refer to it. It cannot be used to install or reinstall Windows Vista, and just serves as a Windows PE interface to recovering your PC. Technically, one could re-create this installation media with freely-downloadable media from Microsoft (namely the Microsoft WAIK kit, a multi-gigabyte download); but it\'s decent of Microsoft to make this available to Windows\' users who might not be capable of creating such a thing on their own.
Read all info at the website about creating and using it:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
ISO Burner: http://www.snapfiles.com/get/active-isoburner.html
It makes a very good Vista Startup Repair Disk.
You can do a Startup Repair, System Restore, etc from it.
Note: It is not a reinstall disc.
Posted on Nov 28, 2013
Why is my all in one computer freezing? It will boot up fine, but after it's on a while it will freeze up, it seems to do it during no activity.
sound like thermal issue or failing hard drive
if it has any built in diagnostic program I would run that at least on the hard drive
Jul 13, 2015 | Gateway Zx4951-33e All In One Touchscreen...
Gaterway zx4951 multimedia drivers will not load...how
The Gateway website lists Win 7 drivers for the 64-bit OS. Are you trying to load a 32-bit OS instead? That's the only issue I could see being a problem here.
Oct 20, 2014 | Computers & Internet
Gateway zx4951
Pay attention to steps 6 & 7
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Jul 07, 2014 | Gateway Computers & Internet
How can i reset thr password
Hi Jon Denver, you did not specify that you are talking about user account password or administrator account password. In both cases you can use password recovery software to reset Windows password. You can click (or can search by yourself) http://lmgtfy.com/?q=Password+Recovery+Software+To+Reset+Windows+Password+Stellar to get a list such software.
Oct 04, 2012 | Gateway " 21.5"" Touch-Screen All-In-One...
Built in webcam on a gateway zx4951
hello,
the link below should solve your problem:
http://www.driversforwindowsxp.com/laptop-drivers/drivers_Gateway_ZX4951_PC-Camera_Windows-7.html
Mar 03, 2012 | Gateway Computers & Internet
Just bought Gateway ZX4951-33e and cannot get wireless keyboard or mouse to work.
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver(if applicable)
make sure the usb device is inserted correctly into the usb port (if applicable)
hope this helps
as for the mouse
make sure the lead has a secure seating if applicable or the usb device
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot the device
hope this helps
May 31, 2011 | Computers & Internet
File: \Boot\BCD Satus: 0xc0000098 Info: The windows Boot configuration data file does not contain a vaild OS entry. I have a windows installation disc
boot to the Windows DVD, select the option to REPAIR, If this is only a software issue, that should resolve.
If it doesn't then run diags on the HDD is it may be failing
Jan 15, 2011 | Computers & Internet
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
