Question about Epson Perfection V100 Flatbed Scanner
HOW CANI LIFT THE TOP OF MY BROTHER MFC 615 PRINTER TO USE THE SCANNER I CANT SEEM TO LIFT THE COVER
    New Friend:
  • 54 Answers
Isnt there any lock button, somewhere on the sides, are you sure you are lifting from the side you are suppose to lift it?
Ultimetly check the user manual.
Posted on Nov 28, 2013
My mfc 6490cw sends blank faxes
Normally this is caused by not loading the item being faxed in the ADF (Auto Document Feeder) correctly. Try sending a Fax of only one page by putting the page Face down on the Scanner plate (Lift the top of the printer to access the scanner plate). if this works then check the ADF scanner plate is not obscured.
Oct 20, 2014 | Brother MFC-6490CW Inkjet All-in-One...
How do I hook my computer up to my mfc-5840cn printer. I have a usb cord but dont know were to hook it up to the printer
There is a spot under the scanner cover of the unit (under the glass). On the right side of the machine you will see a place for youre hand to lift open the scanner cover. One plugin is for USB cable and the other for Ethernet cable.
Also there is a spot for the wire to go through on the right side, a small grove to place the wire so that the cover closes properly.
(still under scanner cover) so it goes out the back.
Aug 17, 2010 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-410CN
When you lift the scan assembly you will see 2 covers that run to the back of the machine, you lift those covers and unplug the cables from the circuit board and take this scanner assembly off. After that there are 7 screws to lift the center cover. You will then see the printhead with 4 ink tubes attached. Cleaning usually doesn't help this printhead, only a new printhead, around $100.00
Feb 17, 2010 | Brother MFC 420CN All-In-One InkJet...
How to remove back corner panel at feeder cable in Brother MFC 8840D
If you mean the top left of the doc. feeder, you remove the cover by flexing slightly, remove a phillips screw, lift the scanner cover and there's a square hole on the lid with one of those flex clip retainers that you use a screwdriver to lift.
Jan 22, 2010 | Brother MFC 8840D All-In-One Laser Printer
Doc cover open errror message on a mfc-8840d and cant' seem to print anything and the mode always is in fax mode and we can't seem to change it.
That error happens when the left hinge in the back breaks and the scanner cover won't shut all the way. temporarily you can tape the switch that is above the hinge and when the error is gone the modes should change again. The hinge is #LP2403001.
Oct 16, 2009 | Brother MFC-8840D All-In-One Laser Printer
BROTHER MFC-240C,UNABLE TO CHANGE 50
This error is usually caused by the Carriage Encoder Strip being dislodged from
the sensor mounted on the Print Head/Carriage Assembly.
Unfortunately, you will need to remove the scanner assembly, and top cover assembly to check to see if the encoder strip has come out of the printhead assembly.
May 05, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-240C
lift the scanner cover until locks into the open position.
you will see the usb socket. plug it
route the cables through the trench out the back of the printer
Dec 19, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother printer, paper inside, but I do not see paper inside.
PAPER JAMMED INSIDE THE MFC
1. Remove the Jam Clear Cover located in the back of the machine..
Squeeze the plastic tabs located on the right and left side of the cover
and pull the cover off.
2. Remove any paper you can see jammed in the machine. If you cannot
remove the jammed paper from the back of the unit follow the in
structions listed below for reinserting the cover and then continue to Step 4.
3. Re-insert the Jam Clear Cover. The top of the cover has a slotted
opening in the center approximately 1/4 inch wide. Hold the cover by the
plastic tabs located in the front of the cover on the right and left side and insert the cover into the opening until it securely
clicks intoplace (both sides).
4. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place.
5. Remove the jammed paper. If the paper is jammed underneath the print
head, unplug the machine from the AC power outlet. Gently move the
printhead to the far right side of the machine (the "home" position) and
then remove the jammed paper.
6. Lift the scanner cover to release the lock and then gently push the
scanner cover support down and close the scanner cover.
To test print the Help List by pressing Menu/Set, 6 (Print Reports), 1
(Help List) and then Black Start. The Help list should begin printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Epson Perfection  V100 Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
