Question about JBL Audio Players & Recorders
Jbl charge will not go into pairing mode
Onlt get blue flashing light, no flashing red
  • 23 Answers
SOURCE: H710 won't go into pairing mode
sounds like its already connected to the iphone but it won't establish them. Delete the pairing from the phone then repeat the process.
Posted on Aug 19, 2009
  • 7 Answers
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Posted on Sep 22, 2009
budmrtn
  • 11361 Answers
SOURCE: JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
Posted on Nov 10, 2009
SOURCE: Cant get LG HBS-250 into pairing mode
Make sure the headset is off when you hold the call button for 5 sec. And don't stop holding it when you hear/see something happen after the first 2 sec. Keep holding it for the full 5 sec. The blue light will become solid which means it's in pairing mode.
Posted on Dec 07, 2009
SOURCE: For some reason, My Motorola H700 quit going into
I have had this problem as well. Just to recap the problem. When you push the talk button and it turns purple, then you flip the speaker boom the unit starts flashing blue and will not pair. If this is the case then you should try unclipping the ear piece on the unit. Then repeat the pairing feature on the unit only this time hold the unit open with additional force. Not so much that you break the speaker boom, but enough to help the unit make a connection when it is flipped open. The problem with these units is that sensor inside does not always make a good connection especially after time and use. This should resolve your problem.
Curtis
Posted on Jun 24, 2010
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
Feb 01, 2014 | Acer C7 Chromebook
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Help pairing jbl charge
Put JBL Charge in pairing mode: turn on Charge. Hold down power button till it flashes red and blue. You're in pairing mode. Go to your device and find Charge and pair up. Done!
Jun 13, 2013 | JBL Tablets & eReaders
JBL Flip blinking red and blue
This indicates that the Blue tooth pairing with the already paired device has been reset and the JBL Flip is ready for pairing with new device. This position, red and blue blinking, can be obtained by long pressing the power buton.
Mar 03, 2013 | Harman Kardon JBL Flip black
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I found my son's plantronics 220. Been in storage a year! I have it charging now. the light is red and ever so often it flashes a blue color for a instant. Is it still good?
Normally the flashing red / blue light indicates the headset is in pairing mode. The red light indicates it's charging but the occasional instant blue is a mystery. The user guide below has the instructions for turning the headset on and off, and pairing to a phone. I would suggest you charge it up, follow the pairing instructions and see what comes up.
http://www.plantronics.com/us/media/media-resources/literature/user_guides/Explorer220_userguide_en_us.pdf?WT.dl=20
Good luck from Headsets Direct - 800-914-7996.
Aug 19, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Voyager pro / can't turn off, can't re pair, light flashes red blue red blue
Had the same problem. Light just flashed blue and red. I decided to put the headset on the charger while it was flashing and after about 30mins of being left on the charger it started working normally again. Hope this works for you.
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
168 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
