Apu has alf fault replaced alt still does same run shut off
3 Suggested Answers
SOURCE: I have a carrier Comfort
I would look at the low oil switch.
Posted on Dec 13, 2010
lpfaff1
  • 11573 Answers
SOURCE: HVAC not working. I do not have any faults
Randy, Being this new of Truck, take it back under warranty and have HVAC repaired.
Posted on May 11, 2016
Testimonial: "Thanks for your help. I was just hoping to find an answer without stopping. I am an over the road trucker and have not had the time to stop"
May 10, 2016 | AC Cars & Trucks
Carier unit starts then shuts down says apu power apu f/b
Low freon: When not running the pressure equalizes. When the unit starts the pressure drops on the low side and the low pressure switch turns it off. This protects the compressor when there is not enough freon to carry the oil it needs
Nov 30, 2014 | Heating & Cooling
Thermoking apu starts up then runs for a min then shuts off and shiws a code ac5 .what is this code?
If the unit starts and runs for a short period then The code will refer to either low gas or excessive gas in the system or the thermostat to control the temperature is set to close to ambient temperature. I would go for low gas from a leak in the system
Jun 22, 2014 | Cars & Trucks
Carrier APU wont shut down and showing SP on screen?
Hi there I have seen this a few time's while working on them. The SP stand's for shore power. If you can't get APU to shut down remove the top inspection cover. There is a lever by the fuel solenoid you can push and hold and it will shut the APU down. Do you know if the APU is equipped with shore power? If not I had one do this to me after I power washed it off. If you remove the top cover on the APU on the back wall on the left had side there is a controller. This is called your APU controller. There are to plug's in controller. remove them and check the weather stripping on the plug. I have seen them leak and let moisture in there and it would cause the APU to do funky thing's. If not it's possibly a APU controller. I'd check them few thing's and if you still can't determine a problem get back with me and we can diagnose further.
Sep 21, 2013 | Carrier Air Conditioner Accessories...
Hi. Alf here I have a Victa Commando 50 year anniversary model which won't run unless i keep pushing the primer, when i stop pushing it the mower cut's out.Any help would appreciated.Alf
Hi, there is a new product called "start" from glod eagle. i have uses it many times and i am sold on it. i have used it to fix problems like yours. here is a link so you can read about it yourself.
http://www.goldeagle.com/brands/start_your_engines/default.aspx
Dec 28, 2010 | Garden
Apu starts fine but no fan no heat and no air conditioning and no 120 volt.
Hi there, Would this be a preheat / comfort pro APU? If so I would start with removing the top cover on the APU. There will be a fuse holder with a 20 amp fuse on the back wall on the left side of the APU above the APU controller. Check and see if the fuse is blown. If it's not then the CCU board under the bunk/ bed isn't seeing power. Either 12v harness or the communication harness both from the APU controller to the CCU board are rubbed on the frame, or the CCU board isn't transferring power properly. The CCU board is under the bunk. There are 4 3/4 bolt's that hold the lid on. Start the APU and look at the board you should have green light's light up. these light's are called input light's. Then chose a function on the driver control panel as in heat, a/c, low or high fan and see if they come on. If the driver control pane are showing the function on look down at the CCU board and see if there are orange light's on. these light's would be your output light's. There's a lot of cause's for this problem if you need further help feel free to ask. Thank's
Nov 08, 2010 | Carrier Heating & Cooling
Apu fails on heater system
Does heat pumps from 1980"s work without freeon for the heat part?
Dec 23, 2008 | Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
