Question about Plumbing
Water continuously is running
The handle will not completely shut off the water
  • 2,113 Answers
Single handle? Two handle? Washerless? Bathroom or kitchen?
Posted on Nov 28, 2013
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
2001 chevy prizm fan runs after engine is shut off until the battery is completely drained
Replace the relay its stuck on,water out the exhaust could be condensation.
May 30, 2014 | Vehicle Parts & Accessories
Constantly running
one of two things one flapper valve bad -or flush valve bad or out of adjustment
Nov 28, 2012 | Sloan M-101526-F42 Flushmate?® Complete...
Cold water runs good; hot water diminished flow then shuts off completely.
Question posted under autocirc recirculating system.
Unknown if system has been taken apart and cleaned with white vinegar, or if faucets are single-handled.
Open following links to help isolate possible problems.
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Crossover.html
Oct 08, 2011 | Laing Thermotech Autocirc Undersink...
Single faucet shower will not completely shut off. small stream of hot water continues to come out of spout
you will need to disassemble the the water control handle and replace the orings in the valve assembly
Jul 09, 2011 | Moen Home
How to stop Toto toilet running? After flush, bowl fills up completely and water continues to run. Jiggling the handle has no effect because cap at end of chain is fully seated. Brand number: Toto...
1. CUT THE WATER OFF AT THE WALL 2. PURCHASE REPLACEMENT INTERNAL UNIT FOR 10 BUCKS AT WALMART 3. INSTALL IT WITH THE INSTRUCTIONS PROVIDED 4. PROBLEM FIXED FOR 10 BUCKS
Jan 26, 2011 | Toto Home
The cold water tap will not completely shut off. With the handle off the cold water slows down but does not shut off. When installed I turned the valve in the direction of instructions before installing...
Not positive about the model you have, but some faucet handles can be put on when the valve is not in the correct position.
Try taking the handle back off, turn it slightly clockwise, and re-install it.
Hopefully this will do the trick.
Good Luck!
Jan 23, 2011 | Home
I just replaced the cartridge in a Moen single handle faucet which was leaking. Now when I push the handle down to turn off the water it pushes back out and a small stream of water continues to run. If I...
I have experienced this problem a few times in twenty plus years in the plumbing business. What I would do is get a moen brass cartridge and give that a try. Hope this helps you thanks
Nov 08, 2010 | Moen & Replacement Cartridge
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Washer ultimate 11
probably bad fill valve ..if water continues to run in when machine is off valve may not be shutting off completely due to trash if screen in cold inlet has been removed to clean and not reinstalled trash can enter valve and prevent complete shut off ..remove 2 screwson back of console pull console forward and roll back pop 2 clips 1 each corner remove lid switch plug cabinet will lean forward and off to acess valve
Sep 02, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
