Question about Samsung Refrigerators
Not cooling and light flashing
Small d on the display
    Genius:
  • 1,198 Answers
It may be stuck in defrost, a faulty timer. They are not expensive, and easy to change. The schematic will show where it is.
Posted on Nov 28, 2013
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
Fujitsu heat pump flashing code?
Test the fuses for the outside unit.
Aug 29, 2017 | Heating & Cooling
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Samsung rs2530 screen went blank except 1 lights bar flashing on freezer and wont cool
The one light flashing on the display is an error code. Depending on which light is flashing will tell you what the error code is. Check the link below to see if it has the error code. That should give you an idea of where to start.
Samsung Error Code List
Mar 16, 2012 | Samsung Refrigerators
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Hitachi projector temp light
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
Your user manual is available at the following link :
http://www.hitachi.us/Apps/hitachicom/content.jsp?page=Products/SupportServices/Support/DiscontinuedModels/index.html&level=4&section=Products&parent=DiscontinuedModels&nav=left&path=jsp/hitachi/forhome/DisplayTechnologiesGroup/
May 20, 2008 | Hitachi CP-X275 Multimedia Projector
Refrigerators Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
