Question about Honeywell HZ-709 Oil Filled Radiator Heater
Hz-789 I cannot power on the unit. I have plug it into different sockets, and the power button still will not come on.
  • 42 Answers
If the sockets are hot (electrically, plug in something to confirm that sockets operation) and you are pushing the right button on the heater, then the unit is defective. There is no type of resettable sensor to my knowledge (not consumer accessible).
Posted on Nov 30, 2013
Reset a Honeywell HZ-709 portable electric oil room heater?
I'm going to ask the first "obvious" question: are you sure the socket you're plugging into is delivering power? (Sorry to ask but it's an Occam's Razor kind of situation) Have you tried a different socket in the same room? Next, does the main power switch for the heater have different settings i.e. high, medium, low, high-high, high-low, low-low and have you tried those combinations? Next, pick up the heater (if it won't hurt your back) and give it a robust shake. Try the power again. Any luck? Keep us posted.
Mar 06, 2015 | Honeywell HZ-709 Oil Filled Radiator...
My Honeywell HZ-717 won't turn on. Suggestions?
  1. If the Socket where the heater has been plugged in is receiving power, the Fuse in the Plug may have blown. Check that.
  2. Check for loose cabling contact.
  3. Since it is new, it must be under warranty, call the Service people from Honeywell first.
Feb 13, 2015 | Honeywell Electric Oil-Filled Convection...
Fluke 789 error when reading AC voltage at 1000 Hz
specification is given up to 500Hz
this is a process meter - not made for frequencies above 500Hz, you need dmm to measure this frequency
Jan 31, 2014 | Fluke Networks Fluke Fluke 789
Fellowes ds16ci
Could have something in the blades that atomatically shut it down. Check for a reset button. Plug unit into different wall socket. Ensure power cable is attached securely to unit. Best I can offer w/o seeing it. GT
Apr 22, 2013 | Fellowes Office Equipment & Supplies
Do jamo powered subs work in the u.s.a. on 110 volts 60 hz
just buy a adaptor like a normal plug socket that your 2 pin 110 volt can plug into it then plug it in to the 3 pin 240 volt socket an bobs your uncle your sorted.
Jan 25, 2013 | Jamo A320 Hcs6 Home Theater Speaker System...
I had the unit set to a second zone that ran into a splitter for four different areas of my house. The second zone is not working, how do I test to see if it is the denon unit or the splitter ?
Plug something other than Zone 2 into the splitter, say, any tape out on the Denon. Keep it simple. Play FM.
When and if THAT works go back to the manual and analyze why Zone 2 isn't working. Observe the Zone 2 Output indicator. (Page 5)
You must have a TV or other speaker-capable device that you can run Zone 2 OUT to. Try that to prove your setup works.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-789-Receivers-manual/id/23110dj895/t/2/
Page 17, 30, 31, 57,65- 68 (you get the idea).
Jun 20, 2011 | Denon AVR-789 Receiver
Will not turn on.... have been on vacation for 3 weeks with all power off from strip plug. the on button does not initialize monitor. plugs are ok and all others work on strip plug including the computer....
Try This :
Unplug the power cable from the Unit
Keep on tapping the power button for next 1 min
Also press and hold it down
Then plug in back the cable and check this should work
Regards Soumajit
Mar 13, 2010 | Acer AL1912 19" LCD Monitor
Have lost power, I purchased a new power supply and cord but still get nothing at the power button. help
You can try a different power socket make sure though it's plugged directly into a power socket without any adapters also check the front button panel to make sure it's firmly connected else your power unit must be blown if you smell a electrical burn from the printer then it proberly is damaged if you are still ubder warrenty I suggest contacting HP or your place of purchase
Jan 25, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Uae customer
even if there is power difference, all you have to do is buy a transformer that would convert 110 volts to 220 volts or vice versa. another issue that to be consider is frequency.
if the unit is designed to run at 60 Hz, then it would be slower when plugged to a 50 Hz supply. and the reverse, it would be faster if it is designed to 50 Hz and plugged to a 60 Hz supply.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Washing Machines
Defective plug Honeywell HZ 680C
just change the plug - get it at a hardware store. if your cord is flat, the center conductor is earth ground, green screw. the ribbed conductor is the neutral (white) and the ribbed conductor is the hot (black)
Dec 06, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Honeywell HZ-709 Oil Filled Radiator Heater Logo
87 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
