Question about GE Stove Oven RanThermostat Electric WB20K10026
What color wires do i connect to what terminal on model number RB540S P2SA THERMOSTAT WB20K10026
Don't know which color goes to which terminal
Where do thermostat wires connect to outdoor a/c unit nordyne s3qa series
I cant see your cable or terminals, I don't know who made the A/C or thermostat - so it's hard to know for sure.
You could look at the other end to see which terminals the red and white wires are connected and connect them to the same terminals at the other end.
Otherwise, they are wired to follow a color code. Red wire to the "R" terminal and White wire to the "W" terminal.
Jul 20, 2015 | Heating & Cooling
Need to know correct color wiring from goodman model gph1330h41 with heat kit to honeywell model th5220d thermostat. Thanks
here is the wiring from man. f you have trouble figuring out the programing or what terminals to use in thermostat there is an help phone number. Be shure to turn off all power to unit and thermostat, remove batteries from thermostat.
jl+ax8un4pr7j8pz3ifmkacgi5aaaaaelftksuqmcc
May 12, 2014 | Honeywell Electronic Programmable...
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
Brother took off wall sensor wiring and now I don't know what colored wires go together
The solid white wire from each sensor goes to terminal #2 and the white wires with the black tracers go to terminal #3.
Sep 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Lux DMH110 therostat, I have four wires; red, white blue and green I don't know there to put the blue wire. On the direction it has Y for a/c compressor I don;t have a yellow wire. Where do...
The color of the wires is a guide only. The lettered terminals on the thermostat are important To pay attention to. R- is 24 volt power w- is heat g- is for the fan y- is for your ac. Sometimes The wire colors matchup sometimes they don't. Your blue wire should go to the y terminal If you have ac.
Aug 28, 2011 | Heating & Cooling
Wiring thermostat to a American Standard 5ton air handler I don't have the schematics Model twe6a300ab serial# e23176168 year 6-1990
On the thermosta there are terminals, what you need to do is look at the old thermostat that you are replacing and make a note to yourself; what color of wire goes to which terminals,, Rc, R, C, G, W, Y, O, ect.
This is because the installer can use any color of wire. Then just hook the wires up to the same lettered terminals. American Standard should be standard terminal setup.
Mar 09, 2010 | Heating & Cooling
I HAVE AN OLD KENMORE CENTRAL HEATING/COOLING GAS FIRED FURNACE. IT WORKS GREAT BUT I RECENTLY UPGRADED THE THERMOSTAT AND COULD NOT WIRE IT PROPERLY BECAUSE I COULD NOT IDENTIFY THE WIRES DUE TO THE...
You will have to look in the furnace to see what color wire goes to the varios terminals on the furnace it should be labeled R,W,G,Y record the wire colors to the terminals in the furnace and wire the thermostat accordingly.
Jan 09, 2010 | Heating & Cooling
I need to know how to rewire my heil air conditioner 6 wires are lose?? they are red white orange black red and purple!!!! Model number ph5036akb4
the wires at the thermostat????...this can be very tricky because the colors could mean nothing...every installer can wire it differently...if they used one continuous thermostat wire it's not too bad....you have to go down to your furnace and look in the fan compartment or wherever the thermostat wires enter the furnasce....generally a brown wire with 5 wires colored inside....find the wires where they connect to the furnace circuit board , terminal strip or fan centre and write down all wires and their corresponding terminals...for example...Red wire is on "R"white wire is on "W" and they may not match their color....thats ok.....then connect them at the thermostat accordingly////if you only have 4 wires you will require the jumper wire between RH & RC ...if you have 5 wires...remove the jumper or ignore that....good luck :)
Oct 31, 2009 | Heating & Cooling
Sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Replacing a thermostat
Typically if you are replacing a heat only thermostat you will have two or three wires. On the old thermostat these wires will be attached to terminals marked "R", "W" and maybe "G". Document what color wires goes to which terminal and transpose these to the new thermostat. If you have a heat and cool thermostat, you will have two or three more wires and connected to terminals labeled "C", "B" and "Y". Again, transpose these wires to the new thermostat as best you can.
Feb 12, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
GE Stove Oven RanThermostat Electric WB20K10026 Logo
42 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
