Question about Dryers
Light on left flashing and dryer won't run
Power is on time is running but dryer is not running
    Sergeant:
  • Dryers Expert
  • 448 Answers
Need more info model # ?
Posted on Dec 06, 2013
2 Suggested Answers
hopper_75
  • 8 Answers
SOURCE: Motor not running light flashing on left side
Did you check that the belt is good?
Posted on Nov 28, 2013
I have a Fridgidaire Model LEQ144ZES0. Dryer will run for about a minute, shut off, then the display lights on far right Drying,Cool down,Prees Saver, Clean lint filter flsah 6 times and then thr Start...
Good Morning Friend,
I understand that you are having trouble with your Frigidaire dryer, model# LEQ1442ES0, shutting itself off after about a minute. I see that the lights to the far right flash 6 times and then the start and cancel button flash 2 times. This also, only seems to occur when the weather is warm and humid. I suggest putting a dehumidifier near your dryer during the warmer months to see if this helps to draw the humidity away from the dryer. The humidity can cause your appliance to not run as it should. The other suggestion I have, would be to reset your dryer. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Nov 28, 2013 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
The flowmeter is the part on the left side of the tub it is where the water enters the tub
The part number for it is W10195536
GENE
Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
I have a roper dryer mod. REX5634JQB dryer will not start, can hear timer run but won t start
sound like a wight thermole fuse on the blower housing remove back you will see it lower left jump wires to see if it will run if so replace and cheak vent
Feb 16, 2010 | Dryers
Whirlpool Duet Front load dryer problem
plug it back in and hit the cancel button if there is one on there
Mar 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
