Question about Philips 42PFL5603D/27 42 in. LCD TV
Reset button DOSE IT HAVE ONE
    Top Expert:
  • Philips Master
  • 75,599 Answers
There is no such button to this set. To make it a system reset, you should enter its service mode option. To get more details, http://electronicshelponline.blogspot.com/
Posted on Nov 28, 2013
Pasquini Livia 90 Auto Dose Panel
First, I'm not a Pasquini tech, but I have worked on several similar brands.
* Most Semi-automatic machines will usually have the program button on the same as the stop button. Some will program all the groups at once or can be individually set up for different pours (shots)
* Holding down the program or stop button for 5-10 seconds will activate the program mode. Note that if you don't press any dosing buttons after 5-10 seconds the program mode will revert to normal mode. Some may cancel out the previous dose set up.
* Before starting, determine what you want a shot to look like. 1 oz, 1.5 oz, 2 oz., etc.
* Set up your portafilter with ground coffee. DONOT change the grind size once your satisfied with the QUALITY of pour (don't confuse this with the amount of the dose. This is handled with the programing of dose water.) Water is absorbed by the grounds depending on the grind size and some times the amount. Pods are different from loose ground coffee too.
* Load up portafilter and place measuring cup(s) under spout(s).
* Press program button and hold for 5-10 seconds. The button will light and stay on (some blink).
* Press the dose button for the appropriate portafilter you have mounted. The pasquini requires you to press the stop/program button once you have achived the desired dose. Other brands require the dose button to be press and held down until the amount of dose water is reached. Letting go button logs the amount in but only after pressing the stop button does it set.
* For other brands, you may need to set up all buttons prior to pressing the program/stop button to confirm dosing of all buttons.
* Remember to keep reloading fresh coffee grounds in the portafilter for each adjustment. Used (wet) coffee will throw out the water dose calibration.
Aloha, ukeboy57
PS; I found a good video from Whole Latte Love site:
https://www.youtube.com/watch?v=1NGN55nYBxQ
Mar 11, 2018 | Pasquini Coffee Makers & Espresso Machines
How to fix white screen upon turn on
if it has not been dropped or water damaged you can try a factory rest ( loosing everything ) Turn off tablet and hold the volume up button and the home button together,then turn the tablet on ( keep holding the volume up and home button ) when tablet starts it will show you a secret menu, you can try rebooting it first from that menu and if it still dose the same thing,if it dose then repeat the steps again but go for reset. ( this will wipe it clean,you will loose everything,so only do that as a last resort ) hope this helps
May 27, 2015 | Tablets & eReaders
Why dose my sharp aquos lc-40d78un power on then turns right back off
No reset button. Probably a problem with the internal power supply.
Jun 09, 2014 | Sharp LC40D78UN 40 in LCD TV
Where is the reset button?
the Reset button is under the black cover where you place your feet.
Jul 02, 2013 | Pride Sonic 3 Wheel Portable Scooter
I have started to use my hdmi cable and it did work but now it dose knot work and the other normal cable dose not work is there any one who can help me
You will need to reset the settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Do 1 (reset system). If
this doesn't work, get back to the menu with the above instructions and do 'system restore'.
Be sure to have the AV cables plugged in.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
I need schematic diagram for sony playstation 2
there is a ribbon wire that attatches to the reset button and to the console it is still attached to the reset button where dose it connect to on the console
May 23, 2010 | Sony PlayStation® 2 Console
Black screen
No your master reset is your reset button that you have to navigate through your screen for that...you might want to take it to the store and see if it's just in need of the battery needing to be replaced.
Feb 10, 2009 | Nokia E71 Smartphone
Reseting Timer
press cancel should reset control board.if not unplug for 5 min.there is no button to reset it! if dose not reste may be bad board
Jan 01, 2009 | GE 24 in. Profile PDW7800 Built-in...
How can i reset my nextel i 930
keep the nemu button pressed while phone is off then press power button it will ask you "press ok to format" and voila done new phone and password reset.
Apr 01, 2008 | Nextel i930/i920/i870 Stereo Headset [OEM]...
Dell dj player
You can reset it with a paperclip. The reset button is on the bottom. When immediately after you reset, hold the play button and you will get the recovery screen. From there you can reformat(erase everything and start over). That should work. If not, you probably have a bad hard drive.
Aug 10, 2006 | Dell Pocket DJ MP3 Player
Philips 42PFL5603D/27 42 in. LCD TV Logo
90 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
