Question about KitchenAid KUDE70FXSS Builtin Dishwasher
Pump clamp failure fixed and now dishwasher clean light blinks 4 times and controls are locked
My kude70fxss2 dishwasher leaked water all over floor. Tech came out and replaced a clamp to the motor. The dishwashe worked two times and now when I tried to run it the green clean light blinks four times and the controls are locked. Any ideas? I read that there is a problem with this clamp and sometimes water gets into the motor when it fails, and then the motor needs to be replaced as well. Apparently this pump clamp failure is common and there was a service bulletin issued but no recall. Do you think the motor needs to be replaced? Any ideas on what the problem could be?
    Master:
  • 435 Answers
I would start by calling that Technician back out. If it is a common problem with your model, did the technician inform you of that when he was there last? Did he even mention the POSSIBILITY that the pump might have water in it and may need to be replaced?
If not, I'd want to know why not. This sounds like something he should have been aware of and checked for, especially if he was a Kitchen Aid appliance service technician. That's the way a "handyman" might do something, but not a certified repairman.
Posted on Nov 28, 2013
  • 6 Answers
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Posted on Oct 17, 2009
  • 901 Answers
SOURCE: KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
Posted on May 27, 2010
  • 36 Answers
SOURCE: Water is not spraying well while dishwasher is
You have to remove the sprayer arm, it's cover, and the cover underneath that located on the bottom of the dishwasher, inside the dishwasher. If you find a large amount of grease/food under these covers then you are not rinsing your dishes enough before placing in the washer.
The disposal unit in these units are nothing more than a cheap metal blade spinning over a metal grate. Anything tougher than a piece of cake and it's frosting runs the risk of breaking the gears that drives this.
Clean all the food/grease that you can access. Be careful while removing the gunk, I have found glass shards from broken dishes. Locate the disposal impeller and screen. It can be removed. Inspect it for damage and reinstall after cleaning.
Your water flow can be restricted if this is plugged.
Posted on Jul 04, 2010
taran_2005
  • 10515 Answers
SOURCE: fills with water heats water will not run cleaning
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 28, 2010
Daniel S
  • 4323 Answers
SOURCE: Kitchenaid dishwasher....clean light will not
Hi
If clean light is blinking indicates an issue with heater circuit, door switch or wash pump. To resolve this please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Posted on Jan 01, 2011
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
F4 message on the top drawer, fisher paykel. I clean the filters and arm every week or two.
There 2 possibilities with this error:
1)
  • Fault with water fill (only on machines with level-controlled fill)
  • Note: Lights blinking, pump running and controls dead indicates an over fill fault
2)--4 Flashes--Draining failure. Drain pump, control board OWI or water indicator defect
God bless you
May 14, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Clean Light blinks, wash cycle does not initiate
The clean light usually will blink due to a failure to heat the water properly. I have put together some information on this and how to reset the machine so it will work again. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 06, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Stainless Steel- LitchenAid diswasher will not star
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light is blinking. dishwasher won't turn on
it is a problem with the heating cycle.Dishwasher “Clean” Light Blinks 7 Times The electronic control looks for a temp. rise of 2° - 4° F.
If no temp rise, the control assumes a heater fault and blinks the clean LED 7x.
Check the heater circuit, water fill, wash pump operation, and neutral side door
switch.
Run a Diagnostic Cycle to reset the control.
REPLACING THE CONTROL WILL NOT RESOLVE THE CONDITION.
All Electronic Controls
S.O.P. – Standard Operating Procedure Whenever an electronic control is suspected
to be the cause of a product failure: before replacing the control, disconnect and then
reconnect all of the wiring harness connectors to ensure proper electrical contact.
I hope this helps.
Jan 24, 2010 | KitchenAid Dishwashers
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Does not go thru dry cycle, clean light blinks 7 times
clean light blinking is a tricky problem to find and cure can be a few different issues.heres an edited down version of official manufacture explaination,its been an issue (I would call manu for assisstance in repairing this further)
A heater fault detection program has been added to the electronic control to check for temperature rise and shut down dish washer. If the temperature rise is less than the criteria, then the unit will drain and blink the clean light 7 times. The Proper incoming water temperature should be between 120°- 140° F.
Possible causes of insufficient temperature rise would include wires off at thecontrol, heating element, thermistor,inlet valve, door switch, motor or capacitor, failure of any of the above components or siphoning of the water during fill.
Feb 27, 2008 | Kenmore 24 in. 16034 Built-in Dishwasher
Leaking water on floor in front of dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
KitchenAid KUDE70FXSS Builtin Dishwasher Logo
239 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
