Question about Protech Water Heaters
Rheem 41vr40 This model of water heater and parts are not posted on Rheem website. I need to know where to get the parts.
    Master:
  • 435 Answers
Did you try amazon.com? they seem to have virtually everything, or at least a link to what you need.
Posted on Nov 28, 2013
  • 2692 Answers
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Posted on Jan 31, 2009
  • 14 Answers
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Posted on Apr 05, 2009
vincob
  • 718 Answers
SOURCE: My gas water heater (Rheem) is making noise, like
Stop wondering, replace the thing and your troubles will be over. Your troubles are inside the tank and not worth even giving it another thought. Go for it!
Posted on Oct 15, 2009
  • 252 Answers
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
Posted on Oct 23, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
I have a Rheem 62sv-40d electric water heater. What type of 4500W element do I need?
Rheem have their own spares site and web catalogue in the main link, but also here as well
Rheem Water Heater Parts - Rheem Parts - Rheem Replacement ...
www.supplyhouse.com/Rheem-Water-Heater-Parts-19213000
  1. Cached
  2. Similar
Here you will find a huge selection of Rheem Water Heater replacement parts. These water heater replacement parts can save you from replacing an entire ...
Rheem - Water Heater Parts - Water Heaters - The Home Depot
www.homedepot.com > Plumbing > Water Heaters > Water Heater Parts
  1. Cached
  2. Similar
Shop our selection of Rheem, Water Heater Parts in the Plumbing Department at ... WiFi Module for Select Rheem Performance Platinum Electric Water Heaters.
https://parts.rheem.com/OA_HTML/ibeCZzpHome.jsp?minisite=10165&respid=52926&grp=IBE_M_OTHER
Nov 20, 2016 | Rheem Water Heaters
I need a serial number for the flame sensor. I cannot locate handboodk
-Generally you have to call manufacturer with model and serial number.
http://waterheatertimer.org/Water-heater-manufacturers.html
-However, Rheem, AO Smith, and Bradford White manufacture most water heaters, and each has parts resources.
-AO and Bradford post their resources under manuals.
http://bradfordwhite.com/documentation
http://www.hotwater.com/resources/product-literature/
-While Rheem hides their parts lists on obscure link, hoping that you will call for a service recommendation.
Here is 2011 parts manual for Rheem
http://waterheatertimer.org/pdf/Rheem-Parts-Guide.pdf
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2015 | Water Heaters
How Do I restart the rheem 81v30d
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Rheem does not post service manuals.
One reason is that water heaters have changed rapidly last few years, and same model might have different features because Rheem experiments to see which products work after they are sold.
Calls to Rheem for DIY help are largely useless since they want you to call local installer or technician... who will sell you a new heater for more money.
Rheem wants to end DIY repairs since doing it yourself saves you money... which means Rheem, and Rheem-loyal service companies make less money.
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
http://waterheatertimer.org/New-government-water-heater-standards.html
Gene
New government water heater standards
Feb 12, 2015 | Rheem Water Heaters
What is the part # for a Rheem 308 71 model heating element needed?
Any generic element will work.
Match wattage with current element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#parts
Rheem wants folks to buy parts from them... so Rheem tries to convince people that Rheem electric water heaters require special parts.
This is not true... ordinary generic parts will function fine on Rheem.
Gene
Oct 14, 2014 | Water Heaters
How can I find the manual to a rheem 21vp50-1 gas water heater? It does not seem available.
For troubleshoot and installation:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Rheem manuals are generic, and contain no service information, or other useful information that would be unavailable from downloading current gas water heater manual.
One site posts talks about 21vp50 but posts generic American water heater manual instead of Rheem
http://homeappliance.manualsonline.com/mdownloads/f918341a-6e8e-41b4-85be-5cde688317b9.pdf
Go to Rheem website, click on power vent, then click tab for Specs/Docs ... and click link for manual and then call Rheem and ask why they do not post service bulletins that match the required maintenance shown in product manual:
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters/
Mar 20, 2013 | Water Heaters
Bought a rheem rete 13 off ebay
Question posted under Rheem tankless water heater:
Call Rheem at 800 432 8373
They will need serial number located on label on side of unit.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually I recommend that people tear out their tankless water heater and sell it on ebay, and then install tank-type heater from different manufacturer:
I would be very reluctant to connect used gas appliance without a product manual, and service manual.
http://waterheatertimer.org/images/Exploded-house3.jpg
Mar 19, 2013 | Rheem Tankless Hot Water Heater...
Can I replace the igniter on my rheem water heater RHLP
1) Rheem does not post service manuals for their brands of tankless, or tank-type water heater:
Replace the thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
2) Probably you can call Rheem and give model and serial number and they will send part.
However, based on responses at fixya, Rheem most likely will not send instructions.
Rheem does not want customers repairing gas appliances.
3) Go to Bosch website, and track down their service bulletins for possible assistance
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
Mar 17, 2013 | Water Heaters
Date of manufacture 81v400, serial r1194849014
1) Rheem 81V40 electric water heater ... manufactured pre 2009 ... posted serial number does not match manufacturer
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-2009-water-heater-parts-by-model-number.pdf page 5
2) Possible date of manufacture 11-1994
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
Where is the combustion shutoff system on a Rheem 30 gal moble home hot water heater
Disproportionate number of water heater problems are Rheem-related, yet Rheem is just 1 of 3 major water heater manufacturers.
If you have Rheem tank-type gas water heater, and the combustion shut off has tripped the FV system, then there is a broken glass vial located under the burner.
Rheem does not post service manuals, and they may or may not send the glass vial for replacement. Depending on model which appears on label on side of tank. Year of manufacture are 3rd and 4th digits in serial number.
And they may want you to contact a qualified service technician (plumber)
You will have to replace glass vial, and clean the arrestor screen and clean the combustion parts, check gas pressure, and check venting.
Other companies post service manuals and do not rely on the glass vial.
Copy following links:
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 09, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
130 people viewed this question
Top Protech Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Protech Water Heater Expert? Answer questions, earn points and help others
