Question about Fahrenheat FUH5-4 Heater
Fahrenheat 54b won't stay running long enough to heat
My heater starts and shuts off. Won't stay running long enough to heat
  • 3 Answers
Fan maybe running to slow and allowing the elements to get too hot and open circuiting the cut out. This will be a fault with the fan or maybe dust and debris in the intake vents.
Posted on Dec 22, 2013
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
Sounds like a bad temperature control switch. If it looks like it can be replaced, check with Johnstone or Grainger Supply company to match it up. Google it for their websites.
Posted on Dec 07, 2007
Buffalo12980
  • 625 Answers
SOURCE: fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Posted on Dec 09, 2007
SOURCE: Parts for Fahrenheat F2543 baseboard heater
Go to Home Depot, buy a new one, take the part you need, return the rest...
Posted on Oct 12, 2008
SOURCE: Fahrenheat F25408 Electric Baseboard Heater noise
Check model and voltage of heater to be sure your heater voltage is compatible to the voltage supplied.
Posted on Oct 26, 2009
I bought a Fahrenheat FZL4004 replacing an older model) and it wont stay on. It comes on, heats, blows, clicks off, & must be manually reset in order to come on again. Help?
Here is the link for the owner's manual. Or call customer service at 1-800-654-3545. http://www.manualshelf.com/manual/fahrenheat/fzl4004/instructions-assembly.html
Mar 01, 2015 | Fahrenheat Heating & Cooling
My fahrenheat fuh-54b won't stay running long enough to heat
Most likely defective thermostat or heat sensors on the unit
Nov 28, 2013 | Fahrenheat 5,000-Watt Unit Heater FUH54
Starts but won't stay running
Did you changed fuel filter.
May 11, 2013 | Cars & Trucks
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
I know this heater worked well. I moved it to another location and had a professional electrician hook it up. It now kicks on but will not stay running long enough to heat anything up. It will shut off...
i take it has a remote thermostat, just remove the 2 wires from it and hold them together, if the unit stays on then it's your thermostat. if it goes out..maybe you overheat safety switch is kicking in..
Dec 19, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
Hi, I just purchased a FUH-54B at Northern Tool and Equipment and installed it this evening. I have a 30 amp double pole breaker installed, and I have 120V at L1 and 120V at L2. The ground is properly...
It sounds like you have 120v from line 1 and line to to ground. What do you have between line 1 and line 2?
You should have 220 or 240v. If you dont have this
the problem is at the breaker. Are the wires going to the same breaker?
If you do have 220 or 240 between line 1 and line 2 at the unit, then it appears thr problem is at the unit,
probably the thermostat isn`t turned up high enough?
If it has a contactor, is it pulled in? If not then there is
a control problem. If you are skilled and confident you
could simply push the contactor in and it should
operate or have an electrician do it. Most of the time
you can bypass the thermostat and close the
contactor that way.
Jan 04, 2010 | Fahrenheat FUH5-4 Heater
Fahrenheat fuh 54 b does not run long enough to get garage warm
have you checked what the operating amps are vs. the amps provided by the outlet. Sounds like you are trying to pull to much load and the machine probably has a saftey to where it shuts down bofore it buns itself up. Hope this helps. You have to be real careful about overloading circuts.
Dec 19, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Fahrenheat FUH5-4 Heater Logo
192 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
