Question about Whirlpool WDF510PAYS Dishwasher with AnyWare Plus Silver Basket - Stai
Wdf510pays2 How do I remove the heating element from my wd510pays2 dishwasher? can I just pull up on the element where it connects into the dishwasher or do I have to remove the unit and do it from underneath? Thanks!
    Problem Solver:
  • 8 Answers
There should be a couple of bolts that hold it on, I wouldnt pull on anything
Posted on Nov 28, 2013
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: How complicated is it to replace the heating
would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Posted on Feb 23, 2009
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
Idw450 dishwasher not heating
pull the cover under the door check to make sure the wires that plug into the heating element are secure. If they are then you need to replace the element. Just unplug the two wires make sure you flip off the breker for your dw . The wires will connect to the prongs that line up with the element inside the d/w then remove the two nuts holding the element in place push up on the prongs and then lift it out from the inside.
Sep 29, 2013 | Dishwashers
Tip
How to Replace the Dishwasher Heating Element
If you have determined that the heating element has gone bad in your dishwasher then you may be wondering if you can easily replace it. Actually for many dishwashers the replacement is not that hard. The most important part is that you turn off all power before attempting to do any work!
The heating element is located in the bottom of the dishwasher tub. It will be submersed in the water when the dishwasher is running. To find it, look for a thin circular tube in the bottom of the dishwasher tub. Some dishwasher will have a cover over it. To get to the heating element the racks will need to be removed from the dishwasher and the cover, if there is one will have to be removed.
To replace the element you will have to remove the front kick plate of the dishwasher. A few screws will hold it in place and they are easily removed. Once you are underneath the tub you can locate the terminal ends of the heating element. Make the wires do you know which one goes where to put them back properly. Then pull the wires from the ends of the heating element. Make sure that you are pulling on the terminal connector and not just the wire to remove them.
Once you have the wires removed from the ends of the element, then look for the lock nuts up against the bottom of the tub that holds the element in place.
With a small adjustable wrench or a pliers you can loosen the locknuts. When the nuts are off of the ends of the dishwasher heating element you can then reach into the tub of the dishwasher and gently work the element loose and pull it up and out.
Place the new element into the holes and then securely fasten the new heating element in place with the lock nuts. Use a wrench or pliers to snuggly tighten the nuts. Replace the wires and the kick plate. Replace the element cover if there is one, the racks, and you are ready to roll. Turn the power back on and try it out!
on Apr 19, 2010 | Dishwashers
Tip
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
http://www.fixya.com/support/r4319937-dishwasher_maintenance
Water temperature is not that hot any more dishes stay dirty after 3rd cycle
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Testing a heating element
Note: Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Use your multitester (aka multimeter) to test the heating element for continuity. Set the device to the ohms
setting x 1. Touch each meter probe to a terminal. You should receive a reading somewhere in between infinity and zero. Because of the variety of makes and models of dishwashers, it is quite difficult to say exactly what the reading should be for each and every possible model. However, if the test you conduct produces a reading of infinite resistance (meter's needle does not move), then that is indicative of a faulty heating element, and you should replace yours. Similarily, if the test you conduct produces a reading of zero resistance (meter's needle moves to the other extreme of the scale), then that is also indicative of a faulty heating element, and you should replace yours.
You do not have to remove the heating element from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Jun 13, 2011 | Dishwashers
My ASKO D3100 dishwasher has no hot water
Well the heating element in the dishwasher might be faulty or not working properly. To check the heating element - Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you. you need a multimeter to check the heating element....... post comments for more help or information......
Good Luck!!
Mar 27, 2010 | Asko D1776 Built-in Dishwasher
Tip
How to remove heating element from dishwasher.
1)      First of all, turn the circuit breaker off  to the dishwasher . The circuit breaker is located  inside  your    home's electrical panel.
2)      After the circuit breaker is turned off , open the dishwasher door and carefully pull the lower dish rack out of  the dishwasher.
3) Then look at the  dishwasher's heating element. The heating element is the very thin, circle shaped  tube  located at the base of your dishwasher.
 4)  Then locate the access panel to the dishwasher  which is directly below the door. Properly remove the screws that secure the access panel to the dishwasher with a proper  screwdriver. There are mostly   two screws at the top edge of the access panel. To remove the screws, you will need to open the dishwasher door and remove them from the access panel.
5) Then carefully pull the access panel out  from the dishwasher. You can use a flashlight to locate the wires that are connecting  to the heating element terminals( the two ends of the element).  One wire is connected on each of the terminal ends. The heating element terminals are located at  the rear of the dishwasher.
 6)Slowly pull the wires out  of the heating element terminals. Hold the wire at the metal leads where they connect to the terminals. If you hold  the wires anywhere else, the wire may get cut in between or wire may break out.
7)Then  you will have to remove the nut  located on each terminal .The nut  secures the heating element tight  to the dishwasher . You have to remove the nut. After the nut is removed , then pull the flat washers and the rubber washer from each terminal.
8)      Then carefully open the dishwasher door and  properly un-clip the heating element from the holding  clips in the bottom side of the dishwasher. Then hold  the ends of the heating element and without applying force on any other part slowly pull them straight out of the dishwasher bottom. You will see two rubber grommets. That should come up out with the terminal ends. If the grommets  does not come up with the terminals and remain stuck up in the bottom of the dishwasher, then pull them out of the holes with bit of force.
9)      Now the heating element is out. You can get new replacement element from local appliance part store. You can reinsert the new element in reverse instructions of how you removed the old element.
Good luck.
on Dec 22, 2009 | Kenmore 15899 Built-in Dishwasher
Water not heating therfore dishes not washing or drying right.
Well the water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Please follow the below steps to check the heating element in your dishwasher -
(Note.Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.)
Good Luck!!
Thanks
Mar 02, 2010 | Hotpoint Dishwashers
Does not heat water
Before testing the heating element, unplug the dishwasher or shut off the power at the fuse box to avoid an electrical shock hazard.
First, open the door and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced.
Jan 31, 2010 | Dishwashers
My Bosch dishwasher is filling and not heating, it drains fine starts filling but never completes a cycle. It is a SHU9956UC
Well you need to check the Heating element, Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Please post comment if you need more help or information........
Good Luck!!
Thanks
Jan 08, 2010 | Bosch SHU9950 Dishwasher
Kenmore Dishwasher Model 665.15912001 Heating element doesn't seem to be heating. Wash cycles are loooooong and the drying cycle doesn't exist. Easy fix or buy a new dishwasher? I haven't tested anything...
Hi. i would test the element first. this will be the likely issue.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. Test the resistance of the heating element using a multimeter. Set the multimeter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading will be somewhere between infinity and zero. The exact reading differs by manufacturer and model. If the indicator does not move (infinite resistance) or moves to the other extreme of the scale (zero resistance) then the element is damaged and should be replaced.
Jul 30, 2009 | Dishwashers
Whirlpool WDF510PAYS Dishwasher with AnyWare Plus Silver Basket - Stai Logo
65 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
