Question about Saws
Wiring assembly needed
The wiring harness was removed and I need to know wiring schematics
    Sergeant:
  • 468 Answers
What's the brand and model of your band saw ? Check out bandsawmanuals.com. They have free dowloadable
manuals and wiring diagram for most brands of band saw machine. You need to register to the site
first before you can download for a manual.
Posted on Dec 16, 2013
Need the pin to pin wiring schematics for this model of motorcycle?
    More images for 1990 Kawasaki 650R wiring schematic
    Kawasaki Motorcycle Wiring Diagrams - ClassicCycles.org
    www.classiccycles.org/1852/597943.html
    Kawasaki Motorcycle Electrical Wiring Diagram Schematics. ... Kawasaki GPZ600 GPZ 600 Electrical Wiring Harness Diagram Schematic 1988 to 1990 HERE ...Kawasaki KZ650 Z650 KZ Z 650 B Electrical Wiring Harness Diagram Schematic ...
    Owner Center - Kawasaki
Jan 21, 2016 | Motorcycles
Decreased power and service stabilitrac
Most likely a bad APP (accelerator pedal position) sensor. You're basically gonna have to replace the entire gas pedal assembly... But it's super easy (so long as you know how to use a socket wrench), so don't freak out. The assembly is held on by two bolts & connected to the computer through a wiring harness. I've seen new assemblies go for anywhere from $60 all the way up to $120, so shop around. Or, if you're comfortable buying used, find an Impala of the same year in a salvage yard and yank it out of that. Simply remove the two bolts that secure the assembly to the floor pan, then disconnect the wiring harness (you may need a philips head screwdriver or something to help remove the clip that keeps the wiring harness securely connected). Pull off the old assembly, put on the new one, bolt it down to the floor pan & reconnect the wiring harness (don't forget to put the clip back in). In some cases, the code will need to be cleared using an ODB-II diagnostics tool (any mechanic or dealership service department will have one & it only takes a minute to clear it), but sometimes it resets itself (this happened in my personal situation). Once the code is cleared, the warning messages & lights will stop popping up on the dash & you're good to go! Hope this helped.... Good luck!
Jan 13, 2014 | 2007 Saturn Outlook
Need wiring schematic for ametek 119550
I had the same problem after not paying attention to the connections when replacing my motor. I spent days searching for information and only found several non-answers with small photos that no one can read.I contacted Oreck for wiring information. They explicitly stated that they can't provide any wiring information for safety and liability reasons.
I found the Ametek schematic which shows the LINE and TAP locations on the motor.
Note: I have a 2600HH XL with 2 headlights.
Connect as follows:
3A, LINE: White lead w/piggy back terminal from light harness #1 & white lead from the power harness to the piggy back terminal
2A, TAP: Black lead from light harness #1
3B, LINE: White lead w/piggy back terminal from light harness #2 & black lead from the power harness
2B, TAP: Black lead from light harness #2
Dec 13, 2012 | Vacuums
How do you put normal cd player in 2004 model ford fusion
You will need an adapter kit for the dash panel specific for the Fusion or a multi kit, both availible at an Auto Parts store. You should also buy the wiring harness for the Car as well, this will make life much easier on you! Connect the harness to the stereo, following the schematic/diagram. Pop the dash panel apart and remove the old stereo. Slide the adapter plate over the wires FIRST, then connect the wire harness, put the adapter plate in place and then slide the stereo in place, re-assemble the dash...
Jun 11, 2012 | 2006 Ford Fusion
My machine wach but do not spin a the end.
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or open circuit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the door lock and switch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Oct 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
Need to replace ignition switch
Ignition Switch (2005 Chevrolet Venture listed but the 2006 Venture was not) Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove or disconnect the following:
    • The SIR system
    • The wiring harness assembly (D) from the wire harness strap (E)
    • The wiring harness straps (C) from the wire harness assembly (D)
    • The wiring harness strap (B) from the upper tilt head assembly (A) chev_vent_col-bulk-conn.gif
    • The turn signal switch assembly connectors (B) out from the bulk head connector (A) chev_vent_passkey-mod.gif
    • The PASSKEY III (B) off of the ignition lock cylinder case (A) chev_vent_ign-swch-screws.gif
    • The key alarm connector (A) from the ignition lock cylinder case (B)
    • The 2 tapping screws from the ignition switch assembly (C)
To Install:
  1. Install or connect the following:
    • The ignition switch assembly (C) onto the ignition lock cylinder case (B)
    • Two tapping screws into the cylinder case.
      1. Torque to: 42 inch lbs. (4.7 Nm)
    • The key alarm connector (A) into the ignition lock cylinder case (B)
    • The PASSKEYS III (B) onto the ignition lock cylinder case (A)
    • The turn signal switch assembly connectors (B) to the bulkhead connector (A)
    • The wiring harness assembly (D) into the wiring harness strap (E)
    • The wiring harness strap (B) into the steering column tilt head assembly (A)
    • The wiring harness straps (C) onto the wire harness assembly (D)
    • The upper and lower trim covers
    • The SIR system
Sep 25, 2010 | 2006 Chevrolet Venture
Im puttin a new head unit with a different wire harness, i know what all the wires are on that wire harness, but with the 92 accord stereo wire harness i need to know which wires are speaker, remote, power...
You can buy a cheap harness from the local parts store for your Honda made specifically to put in aftermarket head units. Since you know the pin outs on your head unit, you can wire it up quickly uning this harness and it will plug directly into the factory Honda harness. Go to Scosche dot com part lookup for your number - I think the wiring schematic is on the outside of the package, too.
Apr 14, 2009 | 1992 Honda Accord
Need to rewire entire jeep
If you want to rewire the vehicle, assuming that you will not be changing any systems, you can usually find complete new wiring harnesses from both the dealer and from aftermarket selllers like Quadratec and JC Witney.  Buying the complete wiring harnesses will be alot cheaper and less time consuming than trying to make them yourself.  These wire assemblies are just a plug and play deal, you disconnect a harness and replace it with the new one.  They may even include some instructions. If you need further assistance with custom wiring or diagnosis, I would recommend getting the service manual for the vehicle from the dealer or used ones from eBay ($30- $100).  The factory service manuals have complete wiring diagrams and schematics as well as full diagnostic information.  These service manuals are NOT like the ones found at your local parts store (Chilton or Haynes).  The factory service manuals are like complete blueprints for a car.
Dec 18, 2008 | 1987 Jeep Wrangler
Need belt schematic for 2006 toyota corolla
I can get you a diagram on monday but it goes from the alternator to the power steering pump then around the tensioner pulley then around the crank pulley then to the a/c compressor then pull on the tensioner to give you some slack and slip it on the waterpump.I hope that helps.Let me know if you still need the diagram
Nov 29, 2008 | 2006 Toyota Corolla
Saws Logo
51 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
