I need a manual for a scientific calculato Senario SC-110
Need to reduce size of projected image from Senario Torpedo Entertainment Projector. I do not have a user's manual. How can the size of the image be changed?
Many projectors have you twist the lens at the front of the unit (or have a separate adjustment near the front). This unit may not have the option, in which case you will need to adjust the image size by moving the projector closer to the screen.
Oct 27, 2013 | Senario Torpedo Entertainment Digital...
Exponent notation won't turn off in Aurex sc-6145
Get the calculator out of scientific notation display mode. Put it in Normal (1 or 2) or Floating point mode. If you have a rest button use it.
Nov 23, 2012 | Office Equipment & Supplies
Casio calculator fx115es inverse key not working consistently
The inverse sine is defined only for numbers in the range [-1, +1].
The sine of a number is at most 1.0. There is no number whose sine is 1.5, which is what you're asking for.
The same applies to the cosine and inverse cosine.
Oct 24, 2011 | Casio FX-115ES Scientific Calculator
How do you raise to a power on a Sharp el-738 business calculato?
I don't know about this specific calculator, but there is probably a button on your calculator that has a "y" with an "x" as a superscript (exponent). Or is could be reversed. But you wanted 2^8, you would push the 2 first, then the exponent button, then the 8, and there's your answer.
Good luck.
Jul 14, 2010 | Sharp EL-738 Scientific Calculator
How to change the paper on canon p23 dhv calculator
Follow the illustrated instructions in the manual available at the manufacturer's web site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
May 20, 2010 | Canon P23-DHV Calculator
49 people viewed this question
jasbo
jasbo
