HP Photosmart C7200
The printer screen turns blue, and has all these different codes, 005FBB6, then all the buttons flash and I'm not sure how to fix it... anyone know how to help?
    Master:
  • 435 Answers
What you see there is an error code. You might be able to look it up in your owner's manual, but if not, start by checking your ink cartridges, to be sure they are properly inserted, then make sure there is paper in the paper feed. Other issues to check are paper jams and stuff stuck inside the printer (like toys, pencils, etc...)
Without turning off the product, disconnect the USB cable from the rear of the product.
Remove the ink cartridges. Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, Disconnect the power cord from the back of the product.
Wait 60 seconds
    1. Reconnect the power cord. If the product does not automatically turn on, press the Power button (3bb271911c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_BI&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalState%3DdocId%253Demr_na-c00551397-8%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3Dhttp%253A%252F%252F16.197.209.193%253A50002%252Fsp4tssearch%252FimageServlet%253FDOCID%253Demr_na-c00551397-8%252Fc01602202.gif%26wsrp-navigationalState%3DdocId%253Demr_na-c00551397-8%257CdocLocale%253D%257CcalledBy%253D%26wsrp-requiresRewrite%3Dfalse&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken"> ).
    2. Reinsert the cartridges, and then close any open doors on the product.
    3. If you receive a prompt to print a calibration page, do so.
    4. If you disconnected the USB cable, reconnect it to the rear of the product.
    5. Try printing again.
If none of this helps, you might want to visit the printer's manufacturer's home page and look for a link for troubleshooting or technical service and support. I always try to resolve the issues myself, first. Good luck.
Posted on Nov 28, 2013
  • 1019 Answers
SOURCE: red light flashing, And little cartridge symbol on printer screen,
Check the ink levels, and that there is not a paper jam.
if nothing of those two, try uninstalling and re-installing printer drivers. sometimes you can unplug the printer for 20-30 minutes. which may enable it to reset to it,s default settings. if this does,nt help. refer to the user manual.
good luck Mike @ Compurepair.
Posted on Feb 20, 2008
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
iskandarsugandi@yahoo.com
Posted on Feb 14, 2009
PeteG0429
  • 34 Answers
SOURCE: C7200 prints blank page between each printed page
Here's a solution. Hope it helped!
Posted on Apr 02, 2009
  • 400 Answers
SOURCE: printer c7200 hp photosmart has new cartridge but
Get your printer little bit serviced...and this problem you are tell about seems to be of the buffer device in the printer it needs to be replaced...
Posted on Jul 04, 2009
SOURCE: HP Premium C309 All-in-One Printer error message "C2FE0065"
I had a similar error (not the same! C2FE0100), and cleared it up with the following procedure:
1) While the HP logo was displayed on the screen, I unplugged the printer. 2) Plug the printer back in. 3) Immediately open the printer so you can see the ink cartridges. 4) Press the power button at least once. If yours is like mine, you see the error just by plugging in the printer, but it takes a minute or so. Pressing the power button for me just caused it to restart the boot sequence where I could get the error again. 5) Wait a couple of minutes. You should see the ink cartridge carrier move back and forth several times, and the screen will display a message telling you the ink access door is open (or similar). 6) I let it move the ink cartridges around for several minutes, but this probably isn't necessary. 7) Close the printer back up. 8) About a minute after closing the printer, it told me that I shouldn't turn it off by unplugging it, and that I should use the power button. 9) I pressed the power button once, and it shutdown. 10) I pressed the power button once, and this time it turned on without any error messages.
I was able to print a photo via bluetooth from my phone, and a short document from my computer, so it seems to be working OK.
Posted on Jan 24, 2010
Ink threshold exceeded
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
Feb 04, 2014 | PrintCountry HP Photosmart C6280 Inkjet...
I have an HP Photosmart C7200 All In One Series. On my previous HP printer, I was able to copy documents and shrink the images. Is this possible on my new Photosmart C7200?
yes it is ,, Once you install the drivers propperly then all the features will be in the toolbar. you can axcessthis tool bar by pressing the copy button on the printer, then you can reduce the image size. Another method is by using the scanner tool bar, aviable in the all programs menu(START / ALL PROGRAMS) once you start the tool bar, simply click copy and folloy the onscreen instructions then set it according to your desire.
Jul 29, 2008 | HP Office Equipment & Supplies
Photosmart c7280 ink threshold exceeded
6. Press OK
Dec 08, 2013 | HP Photosmart C7280 Printer
6. Press OK
Aug 21, 2013 | HP Photosmart 3310 Printer
Error: Ink Threshold Exceeded
6. Press OK
Sep 25, 2012 | HP Photosmart C7280 All-in-One Printer
6. Press OK
Sep 25, 2012 | HP Photosmart C7280 Printer
I have a hp photosmart c7200 all-in-printer and have a desktop which it is setup to. I also have a laptop which I'm tring to setup up wirelessly but having trobule. Any suggestions.
Have you run the Wireless setup wizard from Printer ? If No, Press Setup button on printer front panel - Scroll till Wireless/Network settings - Choose Wireless setup Wizard and follow the directions.
After you have setup printer on network - Run the Printer s/w disk and Choose Add a Device and Choose Wired/Wireless network and continue with the Installation screen.
Jun 24, 2010 | HP Photosmart C7280 Laser Printer
Blue screen of death error
that's a memory allocation code..suggest deleting printer from that panel, removing the software, and starting fresh
check your computer's warranty here 4 FREE
Mar 01, 2008 | HP Photosmart 2710 All-In-One InkJet...
k24674
