Question about GE Profile JTP18 Electric Single Oven
Oven door latch will not release so that I can open the door
Ran the clean mode, cleaning complete, locked light went out. Pushed the latch relase, heard it pop, but the latch did not release and I cannot open the oven door.
    Master:
  • 435 Answers
Try jiggling the door by the handle. Jiggle it hard, both sideways, in/out and up/down. The little piece in there that releases the door may just be stuck, and didn't move quite far enough to let the door open. These things happen.
Posted on Nov 28, 2013
4 Suggested Answers
  • 213 Answers
SOURCE: DOOR LOCK WONT OPEN
do both of you have a digital display? if so are you getting any codes that f- with a number?
Posted on Nov 21, 2007
  • 899 Answers
SOURCE: Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Posted on Oct 13, 2008
  • 385 Answers
SOURCE: cleaning cycle completed. lights out. stop timer
The door will not unlatch until the oven temperature cools down to about 300 degrees.It can take several hours.
Posted on Apr 08, 2011
Oven latch will not open
Sometimes the latch arm is bent causing the latch release not to clear the hook on the door. If the arm goes under the front it is probably bent. Carefully pull the arm back toward the locked position and try to bend it back a small amount and see if the door will open after moving the arm back to the open position. If that fails sometimes you can insert a bent coat hanger between the door and the latch hook and move the latch enough to unlock the door. I hope this helps
Nov 28, 2013 | Ovens
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
I interrupted the cleaning cycle accidentally. The door opened after cooling, and then I tried to restart the cleaning, but now the locking latch is in the lock position with the oven door open. How can we...
First make sure that you wait long enough before you try. If it has not cooled completely it will not release the lock from the lock position. Sometimes if you cycle the power to your oven off and then on again you can reset the oven and the switch may relax, but in your case you may have to lightly pry the latch assembly to the open position. Turn off the breaker to your oven for a good minute or two before reapplying the power again.
If this fails to work then check your manual for instructions or to get a factory service number. They should be able to give you the information you need to open your oven.
Nov 03, 2010 | Ovens
I was cleaning my oven and one of my kids opened the doore before it was finished and then pushed the cleaning button again but did not shut the over door so the lock is up on the door and it won't shut. ...
unplug unit. remove rear cover, see if latch motor has made it to rest position. microswitch may be holding power off to latch. a slight turn may be all you need to reset latch.
hope this helps
Sep 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
I did a self-clean session and the oven remained locked way after it completed the cleaning. The error message on the backsplash reads E1- F5-. I am not able to open the oven. What's wrong?
I hit the cleaning button instead of the broiler and the oven lock went in mode so now it thinks it is cleaning but I can't close it and it won't shut off the cleaning mode. What can I do?
Sep 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door won't open after self-cleaning cycle is complete
Turns out that the latch is attached to a plastic piece (made by the manufacturer) and the spring melted! To boot, the fuse in the back which aids in heating the oven went out also. Repair man said this was typical after several uses in cleaning cycle. He recommended using a gentle steel wool pad with soap built in to gently remove backed on food instead of using cleaning cycle. It is just too hot for too long, and there seems to be a domino effect with things that will go wrong. Nothing like the old fashioned way and a little elbow grease!
Mar 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
GE Profile JTP18 Electric Single Oven Logo
137 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
