Question about HP Officejet 6500a Plus E710n Printer Eprint Wifi Refurbished Fully Tested
Carriage won'y move so I can replace ink cartridges
  • 54 Answers
Look for a release button, ity may be locked in...
Posted on Nov 28, 2013
My HP 940C printer won't move the ink cartridge
Symptom look like carriage jammed in service station,open cover gently try to pull carriage out if its jammed, open top & side covers, release service station capping through manually rotate gears, once its released, push carriage left side, remove service station & verify why its jammed, if found any breakage replace it, or clean it..but little bit technical skill required..see the similar diagram below:
Dec 22, 2011 | HP DeskJet 940c InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
We have just put a new black ink cartridge in our printer and now it won't print. The computer says it is error# 5200 and to see the user guide. The manuals don;t have any info to help. I have tried...
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
Jul 10, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I am not able to get the ink cartridge to go to the centre of the printer in order to take it for replacement purposes
usually you have a button (according to printer's manual) that places the ink carriage to the correct position to replace the ink cartridges, or in print manager of your operating system, if not than you can cheat by powering on the printer and when the carriage unparks (move) power it off immediately before it goes back to the parking position, by pulling the power plug, than you can freely move the ink carriage by hand to the desired position to change the ink cartridge, once that is done you plug the printer back on....
Mar 16, 2011 | Office Equipment & Supplies
Press the OK button to replace ink cartridges
Turn on printer, and unplug power while carriage moving. Move carriage freely to replacement position, Unplug ink tank, remove "something", plug back ink tank. Turn on printer.
Mar 14, 2010 | Epson Stylus CX6000 All-In-One InkJet...
How do you replace ink in EPSON TX110? Paul
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
  1. Turn on the printer.
  2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
  3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
  4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
That's it folks!
Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
Model Cannon MX310 - replaced ink cartridge, both black and color. Window states, check ink - black and color. Will not work. Replaced with new cartridges again. Still will not work
Is the carriage unit moving?If not the carriage motor is defective.If moving the problem is in the carriage unit or logic board assembly.
Oct 07, 2009 | Canon Office Equipment & Supplies
To realign my cartridge carriage i need to press "ink button" cant find it epsoncx5500
Turn on printer, and just unplug power while carriage moving. Unplug USB. Then move carriage by hand.
Jun 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
HP Officejet 6500a Plus E710n Printer Eprint Wifi Refurbished Fully Tested Logo
67 people viewed this question
Seeker5211
Seeker5211
