Question about Comfort Zone Heating & Cooling
We have not used our heater in 6 months. It hasn't been moved. However, now it seems as there is no power going to the unit.
    Genius:
  • 1,198 Answers
Check the outlet with something that works. Look for a tip-over switch that may need to be reset.
Posted on Nov 29, 2013
Comfort zone infrared heater
Check the outlet with something else that works. Look around the machine for a reset button. Some machines have a tip-over safety, see if it needs to be reset.
Nov 28, 2013 | Heating & Cooling
14 month old water heater stopped working
Which water heater do you have??? What is year of manufacture?
Rheem-GE Geo spring hybrid: Rheem-GE heat pump ?? then call GE 888-443-4394 for recommendation of local service technician and expect to pay $400 and do not expect problem to get solved unless area has experienced, certified water-heater-air-conditioning expert.
Installation must be done correctly. For example if water heater is set too close to wall, then service technician will expect you to hire plumber to empty tank and move away from wall and install correctly before repair can resume. It's a nuisance, but this is accurate information based on others who have posted questions.
Copy following link for resources:
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
There are no service manuals available for homeowner, which is why this product is unwise choice for any installation.
Unit is not protected from power surge. Install one-time-use whole house power surge.
Make sure unit is connected to 240V, and that breaker is not tripped off on one leg. Move wires to another same size breaker. Check wire connections at water heater and confirm 240V.
Check that installation is done correctly as shown on link above.
14 months old means that labor warranty has expired by 2 months. However parts are still covered.
Do not buy expensive water heaters that cannot be repaired easily by homeowner. This single repair can eliminate all anticipated savings from buying product.
If expected heat-pump repair will cost $400, then buy off-the-shelf electric water heater from Lowes for $250 and save the expensive repair.
Gene
Jul 25, 2013 | GeoSpring Hybrid Water Heater
Laptop sometimes switches off when moved.
Sounds like a loose connection where the laptop opens and closes hinge there are wires that run from the main screen to the main board. If you know how to take the unit apart it maybe a cheap fix if not then a new laptop maybe the way to go the prices have really dropped from 4 years ago
Jan 12, 2013 | HP Hewlett Packard Compaq 6720s Laptop...
My MP610 powers up, but only projects a weak light, not the usual start-up screen and menu. It has not been used for about 4 months. The bulb only has about 200 hours or less of use. Thanks.
Can you get a menu to come up even though it may be very faint.
Does the lamp appear very bright through the side of the unit like it used to in the past.
Take the lamp out and check if it looks Ok, and also if the glass plate that the light first goes through is clear.
Check if there is anything in the lens unit that might be a problem like dust or moisture.
Apart from that if the unit hasn't been dropped and a mirror inside hasn't shifted then you may have to check the optics system.
Jun 18, 2011 | BenQ MP610 Multimedia Projector
ADK-1 Super------------why is it that I have to relpace the unit or repair it at least 6 times in 9 months? I have replaced the plunger and spring along with the heat sensor each time and still they die....
If you live in an area where you have hard water it can destroy pretty much any tankless water heater, but it seems that you may have another problem, I speak to them on a regular basis and everyone there seems to speak English and Spanish, its very important to make sure that this unit is installed by a liscensed person, whom will check your wire gauge, and breaker size, if you use 240v this unit can draw upto 66 amps, so its important to have an electrician size your heater for the correct voltage.
Feb 02, 2011 | RTO American Heat Tankless Electric Water...
I have a Servi-star 40 Gal. electric SN# SS 0496B15258, How old is this unit? Thanks, Jim
http://www.buyerschoiceinspections.com/water-heater-ages
There seem to be 2 possible answers: Servi-star vs Servistar
Answer #1: Servi-star by American
1st 2 digits are year, 2nd 2 digits are week
This means water heater was made year 2004, 96th week ....it seems wrong.
Answer #2: Servistar by Craftmaster
1st 2 digits are month, 2nd 2 digits are year
This would mean your water heater was made 4th month of 1996
Which answer is true? 6 years old or 14 years old
If tank had 12 year warranty and came with 2 anode rods, and you have good water, and no stray current on pipes, then tank can last 14 years.
If tank had 6 year warranty and came with one anode rod, and you have hard water and a water softener, and you never changed anode rod or drained tank, then 6 years is a long life for the tank.
Oct 07, 2010 | Rheem Water Heaters
When i moved the switch on my Honeywell Thermostat from cool to heat nothing happens
I have 6 of these thermostats, and none of them work....Honeywell customer service provided no help at all. I think the contacts on the switch become slightly oxidized during the months that you aren't using it, making the contact fail. I can't open these units, so for now I am just switching it on and off about 100 times, to try to clean the contacts. This method has worked for 2 of the 6 units so far.
Sep 22, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
61 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
