Comfort zone infrared heater
We have not used the heater since last spring. It has not been moved. There seems to be no power going to the unit. Any. Ideas on what to look for?
    Genius:
  • 1,198 Answers
Check the outlet with something else that works. Look around the machine for a reset button. Some machines have a tip-over safety, see if it needs to be reset.
Posted on Nov 29, 2013
  • 883 Answers
SOURCE: Rheostat vs. Thermostat Temperature Control
yes, it should work. Just ensure your rheostat will handle up to 1500 watts at reasonable settings. A better approach is a 1500 watt pulse-width modulator circuit that draws little power itself. these are available where power tools are sold (like harborfreight.com and known as speed controllers. I use one for a large air fan in my garage.
Posted on Nov 04, 2007
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Posted on Oct 14, 2008
emissionwiz
  • 76132 Answers
SOURCE: I have an AO5 error
what is A05
Posted on Sep 10, 2010
  • 7 Answers
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Posted on Oct 02, 2010
SOURCE: My comfort zone infrared hearter
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Posted on Nov 24, 2010
Comfort zone infrared heater runs for a few minutes a then completely shuts off
if unit runs ok for 3 to five minutes then completely shuts all power lamps off , then its hi temp limit sensor (safety) has been tripped , this usually goes out due to failure of main temp control , in point of fact contacts in temp switch literally weld them self's together and cant separate to allow heater to control temp
Oct 15, 2016 | Comfort Zone CZ1500WC Infra-Red...
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Comfort Zone Infrared Quartz Heater is not staying on it cut right off. Please advise
Clean the filter and the element. Make sure that they are dry before you re-install them. Check the power cord and socket for damage..
Feb 21, 2015 | Comfort Zone Heating & Cooling
We have not used our heater in 6 months. It hasn't been moved. However, now it seems as there is no power going to the unit.
Check the outlet with something that works. Look for a tip-over switch that may need to be reset.
Nov 28, 2013 | Comfort Zone Heating & Cooling
My Cz2011 Comfort Zone Infrared heater will not stay on. It will stay on for maybe one minute and then it shuts off
I had same problem with mine and found out that the timer was turned on make sure your timer time is set to 00 hope this helps
Jan 01, 2013 | Comfort Zone Infrared Quartz Heater
Why does my comfort zone infrared heater shut off after I turn it on? What modes does it have?
What is wrong with my Comfort Furnace heater if i have it turned off and it still keeps blowing ,Yet if i plug it back in it still comes on and i can turn it way down with it down on 55 and it will not shut of like it use to?
Oct 08, 2012 | Comfort Zone CZ1500WC Infra-Red...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Nov 16, 2010 | Comfort Zone Heating & Cooling
How do you change from celcius to farieheit on comfort zone heater
- VS
Nov 28, 2009 | RTO Comfort Zone Electric Portable Space...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
