Question about GE Nautilus 24" Built-in Dishwasher
Remove steam vent - GE Nautilus 24" Built-in Dishwasher
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wa
Nov 04, 2013 | Oreck Steam-It Steam Wand
Model gh3000 spool will not release for removal
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 09, 2013 | Irons
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
Pump wont run
Clean an iron:
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    Steam coming out vents haven seen any leaks yet
    Hello jgreenley32: My name is Roger and I will help you. Steam from the a/c and defrost vent generally means a leaking heater core. The steam usually has a really sweet sickening smell to it. The longer you run the engine the thicker the steam. The way to tell for sure it is the heater core would be to bypass the heater. To do this just remove the heater hoses from the heater core at the fire wall area. Not sure where they are just follow the hoses from the engine back to the firewall on the passenger side of the truck.Remove the hoses and plug them off or put a splice between them. Start the truck and warm up the engine. If the steam is gone ? Then the heater core is bad and needs replaced. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
    Mar 29, 2011 | 2001 GMC Jimmy
    Steam coming out of floating valve on handle.
    No. if the steam is coming out, the vent valve is not seated on the vent and pressure won't build up. Either remove the plastic cover from the vent valve or slide it up enough so that the valve seals on the vent. If you remove the plastic cap, you will need to manually tilt the valve to "quick-vent" the cooker. Watch out for steam burns! Should work fine after that. You need to unplug the cooker and re-plug it to reset the "E4" error message.
    Jan 16, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    2001 Jimmy, ran a little hot and steam was coming out of the window defrost vents, changed the thermostat now steam is really comming out of the window defrost vents. What do we need to do?
    You heater core is leaking causing steam to come out of the interior vents. This is quite a process to replace a heater core in one of these cars. The entire dash needs to be removed. The core itself is located under the middle of the dash towards the top. If you do this job yourself, take your time and allow a full weekend to do if you've never done one before.
    Aug 16, 2008 | GMC Jimmy Cars & Trucks
    Tumble dryer problem
    nnot removing steam from drum???? you open your dryer and you see moisture???, if this is a stand alone dedicated dryer ( not a combonatin waher/dryer in one tub), you have a severly clogged/ blocked vent.. you will need to revent or clean the venting as soon as possible
    Apr 05, 2008 | Dryers
    GE Nautilus 24" Built-in Dishwasher Logo
    Top GE Dishwashers Experts
    Mike
    Garth Jackson
    jdthefixer
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
