Question about Garden
When trying to start up with electric start once in awhile it starts ok but usually u crank until the battery starts weakening,and one pull on the recoil and it starts right up
I have cleaned the vucuum fuel pump the inline filter all the electrical connections between the battery and starter and the battery is new this year.I also cleaned the flywheel up and the magnetic pickup. the spark plugs were gapped and replaced twice.We have another machine,same thing to compare with and my starter does not drag,while I was in there I put A dab of STP lube on starter drive bushing.Any ideas?
  • 528 Answers
I suggest checking the ignition switch - I've seen switches do this before, where the switch powers up the starter solenoid but cuts the power to the coil. Test coil output while ign.is in start position - if the voltage is low or non existent, there's your problem!
Best of luck and thanks for using Fixya!!
Posted on Nov 28, 2013
4 Suggested Answers
  • 68 Answers
SOURCE: electric start clicking
Check the battery with a VOM while pressing the start button. If you have good voltage check the voltage on the positive cable on the starter. If you have good voltage there you have a bad starter, considering your cable connections are clean and tight. If no voltage at the starter the solenoid is no good. Usually the click is the solenoid closing and if the connections are not clean or tight the current will not make it to the starter.
Posted on Mar 25, 2009
SOURCE: QUAD WON'T START
add gas
Posted on Aug 17, 2009
  • 15 Answers
SOURCE: having problems with my 2005 polaris sportsman 4x4
try jumping the two posts on the solenoid near the battery with key on , then try to start , if it starts or turns over it needs a solenoid, or the bendix is hanging up on the flywheel,had the same problem and took off my recoil cover and found teeth on bendix all chewed up and stuck on flywheel. try to pull the recoil start first and see if that releases bendix, if not remove recoil cover for inspection,or your starter is bad, if it sounded like an old dodge starting up prior to it not starting , its probably the bendix
Posted on Dec 27, 2010
Nissan Frontier V6 2007 will not start in cold weather. Battery ok. Will crank but not start. Using battery booster will start and run fine. What would cause this?
You may have a failing starter. After about 5 - 7 years the battery begins to weaken it will allow your starter to kick but the starter itself may be too worn and too weak to keep your flywheel turning.
Jan 07, 2016 | 2007 Nissan Frontier SE Crew Cab
2008 titan cranks no start no communication with modules pops off every once and awhile usually when battery voltage drops
Battery Dead ?
Why does the battery voltage drop & why
are you not working on that issue ?
What has been tested so far & how & results ?
Nov 14, 2014 | 2008 Nissan Titan
I turn ignition car makes a sound but want start what is wrong?
Not quite enough info here. Does the starter sound normal? Is it turning the engine over but the engine will not start. Please explain what "makes a sound means". I want to help.
Sep 26, 2014 | 2004 Mercury Sable
Car clicks but wont start
the alternator lamp will not go out until the engine runs..
the alt converts engine horse power to electric power,
no engine, no alt.
so that means the engine will not start, or better it wont crank
subzero C or Subzero F.,, -10F or -10C, vastly different temps.
no crank, then jumper cable crank it with donor car running.
crank now,?
yes , then battery is bad,weak or just discharged.
no, then starter bad, or key line bad.
hot wire starter solenoid. cranks now, is bad key line
if not, bad starter.
did you wiggle the shifter at crank.
did you wiggle key. extra.
did you try crankiing in neutral using fresh start contacts.>... yah.
Jan 29, 2014 | 2000 Toyota ECHO
2004 trailblazer doesn't start on first try. It cranks and eventually starts but usually 3-6 tries. Once started it runs fine. I have no check engine light. We have replaced the spark plugs, b
For engine to run it has to have:
Fuel, air and spark.
So if it doesn't start, something's missing.
Is your fuel pressure OK? Is your spark present? Is ECM firing injectors?
Check all those basics and I'm sure you'll find what's wrong.
Jan 10, 2018 | 2004 Chevrolet TrailBlazer
Questionable start up
Hank doze your harley have decompression knobs on the heads? check it out at harley shop . I don't think lucas oil will make a differance good luck CJ
Jun 01, 2010 | 2004 Harley Davidson FLTRI Road Glide
Had door to f150 open for awhile truck was running all of a sudden it shut off and i cant get it restarted. just clicking noise and panel not working lights dim HELP!!! its done this once before when i was...
Sounds like a problem with the recharging system.
If you had a lot of electrical running such as headlights, stereo, interior lights, heater etc there is a large draw on the electrical system. At idle you could run the battery down. Jump start would solve the problem.
The clicking you hear could be one of two things.
1. The starter relay operating. This sound would come from the fuse box.
2. The starter solenoid engaging the stater motor. This would come from close to the engine where the starter is mounted. If the power is low the solenoid engages the starter but there in not enough power to turn the engine over. Again a jump start would solve this.
Sometimes it will go later after everything is shut down and the battery has time to "relax" from the draw or the temperature is higher. All can help a start.
You may have a weakening battery that is having trouble holding a full charge. A battery shop can bench test the battery for you.
If it is OK if could be a failing charging system.
If you have has a squeaking sound at idle or when cold and wet your alternator belt may be loose. It can be easily tightened.
If not your alternator may be weakening. Again a repair shop can test for output. Or simply test with a voltage tester to see the output.
If all is OK it could be more advanced in your charging system. For a do it yourself fix. Go the the library and get a copy of the Bently service manual for your yr of vehicle make model.
Adrian
Mar 07, 2010 | 2004 Ford F150
Runs down and wont crank after setting over night will jump start
It could be the battery, corrosion on the battery terminals, or it could be something drawing current while the car is not running - especially if you've recently any kind of powered accessory in the car. For a self-test, you can disconnect both battery cables (negative first) at night, clean any corrosion that may be on the battery terminals, and then reconnect only the positive cable. Reconnect the negative cable in the morning, and if the car starts easily you can be pretty certain that the problem is a current draw. If not, it's definitely the battery. Given the year of the car, if it still has the original battery in it, you probably need to replace it.
BillB
Feb 21, 2010 | 2006 Toyota Corolla
Mazda RX8 won't start, Engine will crank but won't start.
you have flooded the engine if you go too you fuse box and take out the fuel pump fuse turn the engine over for a while this gets rid of the fuel left in the cups in the engine replace the fuse try it again it will start
Jan 31, 2010 | 2004 Mazda RX-8
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
