Question about HP Officejet 5610 All-In-One InkJet Printer
I want to use the ADF to scan photos but want them to come out bigger
I want to scan 5 x 7 photos and use the ADF. it works fine but the photos come out small. is it possible to change a setting and have them come out larger as if they were scanned on the document table using the multi scan option?
  • 2,113 Answers
I just scan to the computer. Then in microsoft publisher i resize the picture the size i want by moving my mouse... i put it on the sheet exactly where i want it and print. I don't even have to save the publisher to do it. You can also resize fast in photoshop or any other photo program like Picasa (free online)
Posted on Nov 28, 2013
  • Stan Budz
    Stan Budz Nov 28, 2013
    thanks. I am scanning a few thousand photos and have 3 scanners. The epson and cannon create nice sized one's. but the HP doesnt unless I use the Document table.
  • Stan Budz
    was hoping that there was a setting to change it.
4 Suggested Answers
adonscott
  • 106 Answers
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Posted on Jul 04, 2008
SOURCE: HP OFFICEJET 5610V No scan options
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
Posted on Jan 01, 2009
YourZEN
  • 820 Answers
SOURCE: How to scan using a hp officejet 6500?
Support overview for the HP Officejet 6500:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3795314&lc=en&cc=us&dlc=en&lang=en&cc=us
See the user guide from page 48 (=44) for how to scan:
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
To use the scan features, your device and computer must be connected and turned on.
The printer software must also be installed and running on your computer prior to
scanning. To verify that the printer software is running on a computer running Windows,
look for the device icon in the system tray at the lower-right side of the screen, near the
clock. To verify this on a computer using Mac OS X, open the HP Device Manager, and
click Scan Picture. If a scanner is available, it will launch the HP ScanPro application. If
it is not available, a message appears to let you know that a scanner was not found.
Select Software & Driver Downloads in the support overview and next enter your operating system to get to the required software.
Posted on Dec 05, 2009
Laserjet m5035 line when colour scanning
Check to see if not only the ADF is spotless, but the prism below it. If there is something stuck there you could see it.
Dec 30, 2013 | HP LaserJet M5035 MFP Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Dell photo printer states: "clear ADF
Adf stands for automatic document feeder. It feeds the your original onto the scanning glass.
Apr 15, 2011 | Office Equipment & Supplies
Copy off glass copy is good. copy from ADF copy is blurry
The problem is either dirty glass for the ADF which you can clean, or the ADF cannot feed the paper you are trying to scan through accurately. Most smaller all in one printers use the same scanner element for both the ADF and flat glass scanning so the fact that glass scanning is fine points to the two problems listed above.
Mar 29, 2011 | Office Equipment & Supplies
Scanning a document from the ADF results in a line down the middle of each page scanned. Scanning from the platen (not using the ADF) works fine
Lift the scanner cover so that you can see the platen glass. Look to the left of the large sheet of glass and you will see a narrow strip of glass. This is the area used to scan documents fed from the ADF. Make sure that this glass is very clean. Use a damp cloth to clean any dirt or buildup.
Feb 10, 2010 | Canon PIXMA MX7600 Multifunction inkjet
How do I scan more than one page at a time
To scan more than one page at a time you can use ADF.
The Automatic Document Feeder (ADF) can scan multiple pages, including duplex pages. When using the ADF:
* Load the document into the ADF faceup, short edge first.
* Load up to 50 sheets of plain paper into the ADF input tray.
*Scan sizes from 148 x 210 mm (5.8 x 8.3 in.) to 215.9 to 355.6mm (8.5 x 14 in.).
* Scan documents with mixed page sizes (letter and legal).
*Scan media weights from 52 to 120 g/m2 (14 to 32 lb ).
* Do not load post cards, photos, small items, transparency, photo paper or the thin media (such as magazine clippings) into the ADF. Place these items on the scanner glass.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Lexmark X7350 All-In-One Printer
When scanning we are getting this error msg. Syntax error in parameters or arguments
First try to print a test page and see how it looks. If it is fine goto the copier --- are you trying to scan through the ADF or off the glass? IF you are trying through the ADF try off the glass. If fine off the glass the ADF scan/ reading problem. Check to see if you can make a regual copy. If copy is fine but can not scan through ADF or off of glass, uninstall the scan drivers and download the latest drivers from the makers website, paying close attention to the proper drivers for device and your OS ( operating system). If with the lastest drivers the problem continues you have a scanner problem and need it repaired or replaced.
Jan 02, 2009 | Toshiba e-STUDIO 282 Black and White...
Scanning Photos using ADF
Under the MP Navigator software, go to Platen scanning, then under the Document Size box on the left side, click the "specify" button. Then switch document size from "auto-detect" to 4x6 portrait or 4x6 landscape. Select "ok" and that should do it. Make sure you line the photo up correctly on the platen.
Nov 16, 2008 | Canon PIXMA MX310 All-In-One Printer
When scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
How do I scan a bunch of originals from the tray and get 1 file for each page?
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
May 13, 2008 | HP LaserJet 3030 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
202 people viewed this question
Seeker5211
Seeker5211
