Question about Cafe Manila Cyber Cafe Management Standard
Cafe serrver run time error 13 type mismatch
Error Dimension mismatch on ti89
Error Dimension Mismatch:
Two or more arguments must be of the same dimension. For
example, [1,2]+[1,2,3] is a dimension mismatch because the
matrices contain a different number of elements.
Mar 23, 2016 | Texas Instruments TI-89 Calculator
How do you fix error EAA002
Has to do with your LAN cable a mail serrver
Apr 28, 2014 | Konica Minolta Bizhub 222 Black and White...
What is a error C2563: mismatch in formal parameter list in c++ language
ok, look at the following example
void Run(string* message, char& type)
in the program I put
Run("help");
this will result in the mismatch error as there are two parameters not one.
Regards
gewiz.co.uk
Oct 28, 2009 | Microsoft Visual Studio 2008 Professional...
Run time error 13 type mismatch
It could be (and I am not a programmer either) is that there is somecorrupt entry in the registry or in the installation folder of yourAstro program.
This is what I would do.Try do completely de-install the program. I would use the free revo-uninstaller (you can get it here) and choose option 4 (Advanced). Delete all associated files that the program finds.
The huge advantage over MS's Add or Remove Programs is, that it also catches unnecessary program files left behind on your computer.
Download ccleaner (from here, make sure not to install the stupid Yahoo! Toolbar in "Install Options"!) and install it. Don't run it yet!
Restart your computer and run ccleaner (both clean and Registry)and get rid of all the ****. If you want to be super careful, you havethe option to make a registry backup from within ccleaner.
This way you (hopefully) have deleted any traces of older installations of the Astro program.
Restart your computer again after the cleanup and try to re-install your program again.
If you have any more questions or this suggestion did not work, just come back here and leave a comment - I'm happy to help.
May 19, 2009 | Gateway GT5220 PC Desktop
Type mismatch in MSFlexGrid Control
type mismatch error occours when there is a mismatch between the value which you are trying to assign to a variable which is dimensioned to store values of another, first you check if the datatypes match each other by applying the break.
Dec 19, 2008 | Microsoft Visual Basic 6.0 for PC
Paper mismatch when recieving a fax
I understand that while receving faxes, you are experiencing with paper mismatch error message.
Please select the paper type as plain paper fromt the front panel of the All-in-One and try to recevie faxes.
Mar 27, 2008 | HP Photosmart 2710 All-In-One InkJet...
Regional codes
The DVD region cannot be changed more than 5 times without 3rd party software which is very hard to find now as it has even been restricted in Europe.
You can look for "dvd region css free" online but you may not be able to get it anymore.
Dec 25, 2007 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
Top Cafe Manila Computers & Internet Experts
David Payne
David Payne
Are you a Cafe Manila Computer and Internet Expert? Answer questions, earn points and help others
