Susan P Shanks
Why can't I get on to Netflix?
I used a slow cooker for the first time with lamb shanks and potatoes ect and it was an utter failure.the shanks were sitting a bed of vegetables and liquid.
many people prefer them that way . if you want them dry then you have to use a rack to elevate the shanks off the bottom
Jun 03, 2017 | Crock Pots & Slow Cookers
On my Amazon Fire TV, have trouble getting YouTube....streams broken up voice and video...how do I fix?
Hello Susan,
Have you tried doing any updates to your Fire TV Stick? Go to settings- system- about- check for system updates- you will get a warning about using the original power connector and wall outlet. I'd recommend using it if possible.
Apr 14, 2017 | Amazon Computers & Internet
How can I connect vizio to Netflix
Select the Netflix icon and open the settings. Go to network setup and login as you would on your computer.
Jan 03, 2015 | Vizio XVT553SV 55 in. LCD TV
Susan delaney
Shut down the device, and then disconnect the internet and then reboot after 15 minutes
Nov 13, 2013 | Computers & Internet
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
Can I buy a zipper foot attachmet for the Kenmore model 1703 sewing machine?
You can find generic presser feet at fabric stores. Hancock has a great variety - JoAnn, not so many.
Take a presser foot with you when shopping so you are sure to get the right shank - the newer machines have low shanks and the old ones long shanks.
Feb 20, 2010 | Sewing Machines
American Standard Easy Touch Pull-Out Kitchen Faucet disasimble
grab a basin wrench ther eis a couple of eather plastic screws or something on the 2 shanks comming down that should do it if it is stuck from years of crud build up u may need to wiggle the faucet a bit to break free good luck man 99 percent of the time those faucets are mounted by the 2 shanks comming down threw the 2 holes in the sink
Apr 12, 2009 | Plumbing
Different Bit shanks
Those with larger bit shanks can hold larger blades. For large joinery cuts, buy a router with a large bit-shank diameter.
Aug 27, 2008 | Dewalt DW618PK Factory Reconditioned 2 1/4...
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
