Question about Fujitsu Siemens Computers & Internet
Start up shut down - Fujitsu Siemens Computers & Internet
My tool improper shut down detected checking file system please help me
that message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
Oct 25, 2016 | Computers & Internet
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
How do i turn off windows 8
1. In Windows 8.1, from the Start screen, click the Power button and select Shut down.
If you can't see Start screen, point the mouse to the bottom-right corner of the screen, click Settings, then click Power, then click Shut down.
2. From the Start button, select Shut down or sign out and then Shut down.
Jul 08, 2014 | Computers & Internet
Turn off windows 8
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
Shuts down going down the road shuts off completely
vehicle shuts down while driving down road and does not start backup for at least 20 minutes, could be a bad crank sensor. if bad it will start and run fine, but it will keep shutting down until fixed.
May 16, 2010 | 1997 Nissan Pathfinder
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Compputer shuts down abruptly
If you have recently fitted new hardware. Take it out.
If not, buy a power surge protector from your local pc store
Jan 30, 2009 | 2005 Mercury Villager
Computers & Internet Logo
107 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
