Question about Aqua Brass Akro Shower Kit #2 AQUA BRASS AKRO-KIT2-BN
Thermostatic valve does not turn - Aqua Brass Akro Shower Kit #2 AQUA BRASS AKRO-KIT2-BN
    Top Expert:
  • 12,223 Answers
Followt this steps and fix it. God bless you
  1. Turn off the water supply and open the faucet handle to relieve water pressure.
  2. Carefully pry off the trim cap with a small screwdriver or putty knife.
  3. Remove the locknut with an adjustable wrench, then lift the spindle out of the faucet.
  4. As needed, remove and replace the O-ring. Before reinstalling, coat the stem lightly with plumber's grease.
  5. As needed, remove the retaining screw and pry out the washer. Install an exact-replacement washer and tighten it.
  6. As needed, inspect the seat and replace if damaged.
  7. Install the valve and tighten, then reinstall the handle and test.
Posted on Nov 28, 2013
Hello,I have a Imperial IFS deep fryer S#06301407 .We had a pinhole repaired in tank.I know that tank was removed prior to repair .Unit did work fine other than leak before tank repair.After lighting pilot...
You can use a jumper wire to test the valve. The voltage is LESS than 1 volt so do not worry. Imperial fryers usually use a robershaw gas valve. the 2 outside terminals...left and right.... are where the thermostat connects. Using a jumper wire after the pilot is lit will tell you if the valve is good or if it's the thermostat. You can also use a multimeter and check the continuity of the thermostat.
Tom
Jun 08, 2010 | Imperial IFS40 Deep Fryer
Pilot light stays lit when I turn the gas valve to on. But nothing happens when I Turn the thermostat on. Help
The thermostat control is bad, you will need to replace the thermostat switch and everything will work just fine. Basically the thermostat switch is not sending a signal to the gas valve telling to to turn on
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
Fryer heats up to 550 degrees and shuts down pilot and triggers the reset button which thermostat is it the operating on or the high end on i have already replaced the gas valve
Either the thermostat is bad or there is a gas leak between the gas valve and the thermostat. Use a soap solution and apply it to the 1/4" gas lines between the thermostat and gas valve. If bubbles appear then you need to fix the gas leak. If no bubbles appear then set the gas valve to the pilot position, remove the gas line marked "out" (the left one) from the gas valve. Turn the gas valve to on. The burners should turn on. Place you finger over the hole where the disconnected line was and the burners should turn off within 10 -15 seconds. If this happens then the thermostat is your problem.
Feb 24, 2010 | Pitco Frialator 35CS Deep Fryer
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Heater won't turn off. Wires were troubled
Shut off the gas to the heater. Bad gas valve. Gas should not be leaking from any part of the gas valve.
Oct 21, 2009 | Cozy (W352E) Heater
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Thermostatic Valve Shuts Down on Full Volume
I would check the strainers/filters becuase clogged strainers can lead to decrreased water pressure and therefore improer mixing... there may be strainers at the supply valves, at the intake to the faucet and the cartridge...
Nov 18, 2008 | California Faucets 1/2" Thermostatic Valve...
HEATER DOES NOT TURN ON BUT AC WORKS.
- If no voltage output at the thermostat for the supply of heater/reversing valve, then replacement of thermostat is needed (but check the thermostat setting).
- If the voltage output at the thermostat for the supply of heater/reversing valve is present, then then check for heater/reversing valve fuse or overheat protection, and check for defective heater/reversing valve
Jan 03, 2008 | Honeywell Programmable Thermostat Heater
Aqua Brass Akro Shower Kit #2 AQUA BRASS AKRO-KIT2-BN Logo
127 people viewed this question
Top Aqua Brass Home Experts
Donni Steen
Tom Chichester
Are you an Aqua Brass Home Expert? Answer questions, earn points and help others
