SOURCE: 5100 canon mp 180
5100 is a carriage travel error. Make sure there is nothing stopping the carriage from moving all the way from right to left, and then clean the encoder, the plastic strip behind the carriage with a Q-tip damp with water, grease on that strip can give you that error...
SOURCE: como reparar el quema cocos pues se quedo atorado
Es posible que tenga que comprobar los fusibles en primer lugar, despu?s de que compruebe si est? recibiendo energ?a al motor el?ctrico. Y si todo lo dem?s falla mirar a ver si hay algo en la pista bloqueando el techo solar
SOURCE: COMO REPARAR EL CODIGO P1381 EN HONDA ACCORD 1999
For
OBD code problems check the list of help links below. Click the link
below to go through its procedure. -------------- -------------- ------------ ------------- -------- ------------ -------------- ------------ http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html ---------------- http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html -------------- http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html ------------ ------------- http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html -------------- http://howtobyme.blogspot.com/2011/11/code-p0452.html ------------- http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html ------------- http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html ------------------ http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html ------------- http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html ----------------- http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html ----------- http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html ---------------- http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html -------------- Part 1. http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html -------------- Part 2.------ http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html ------------ http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html -------------- http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html ------------------ http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html ------------- http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html -------------- http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html ------------ http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html ------------- http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html -------------- http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html ------------- http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html ----------- http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html ----------------- http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html ------------- http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html ------------- http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html ------------ http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html -------------- http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html ----------- http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html ------------- http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html --------- http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html ------- http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html --------- http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html ----------- This
will help. Thanks.
Diagnostic Code P2195?
http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330?
http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330?
http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300?
http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768?
http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions
System codes details?
http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html
Engine Misfire codes?
Misfire on cylinder 4?
ABS trouble codes for all models?
Diagnostic code P0010?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
Code P0452?
OBD code P0172 on Buick?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
OBDII scan is receiving NO
BUS CODE?
How to Clear OBD error
Codes?
Diagnosis and Testing Car
Components?
Diagnostic Trouble Codes
list?
list?
OBD Code is cleared but
check engine light will not RESET?
Diagnostic Code 43 and 71?
Code P0132?
P0031 code?
How to get diagnostic Code
without OBD Scanner on Pre 1995 cars?
OBD-II Trouble Code P0300?
Getting diagnostic code
P0016?
How to Read Codes from
Check Engine Light?
Diagnostic Code P0540
continues to return and the MIL light is on?
DTC Trouble Code P0401?
Car misfires and error code P0306 and P0303 is
shown?
Diagnostic code P0463?
Check engine light with
codes P2195 and P2197?
Diagnostic error code
P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
P0174, P0037 and P2197?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0301, P0430 and
P0174?
OBD code P0500?
SOURCE: como reparar este codigo P0171 en un kia sorrento 2006
Here's a link on your code. P0171 Nissan Fuel Injection System Too Lean Bank 1
