Question about KitchenAid KSM150PS Artisan Series Stand Mixer
My Kitchenaid Mixer Model KSM150Ps is tripping my breaker after replacing the speed control board.
My mixer stopped on its' own while grinding meat. I checked and replaced the brushes as they were in there, I checked and replaced the speed control board, and now when I plug it in, it pops my circuit breaker. What is my next step to take?
    Problem Solver:
  • 8 Answers
Try a different Receptacle outlet if it trips that breaker you know its the mixer, and there will prob be a short/loose connection somewhere
Posted on Nov 28, 2013
  • 9 Answers
SOURCE: Kitchenaid Mixer K45SS
I just did this last week!
1 Unplug Mixer 2 Remove screw on TOP of mixer body, at back. 3 Remove rear cover and paper-gasket thing (its not the end of  the world if you end up tearing it a little). 4 the phase control (little circuit board w/wires) is at the top (you  should see it very easily) held on by one screw, remove it. 5 when the circuit board is unscrewed, disconnect all the wires  that are connected FROM THE CIRCUIT BOARD to the  black control plate (NOT all wires-there should be 4 left on  the control plate at this point).  you don't need to  remember where all the colors go as the control plate is  labeled->but looking at them and making sure you  understand the abbreviations would be beneficial  (BK=black, BL=Blue RW=Red&White W=white R=red etc.   6 install new phase control (screw), either buy new thermal  grease (used to keep the board cool->it transfers heat to  the mixer's housing) or try to salvage what you can from  the old one. 7 connect wires, paying attention to labels. 8 reinstall paper gasket, then cover, then screw to hold on back- cover.
Posted on Feb 09, 2008
SOURCE: kitchenaid mixer k45ss slow gear
If you look into the brush holder you will see a stopper at the botom ,(this is so when brushes are wore the spring is not driven into armature) .. the brushes have to be inserted so the groove is lined up , try that
Posted on Apr 07, 2008
  • 16 Answers
SOURCE: Mixer goes really fast then stops
First thing, check the Hall Effect Sensor (part # 9703312) to make sure that it is seated snugly AND properly!  The Hall Effect sensor measures the speed of a tiny rotating magnet and basically tells your mixer how fast it should rotate.  I was experiencing the same problem that many others have described here--my mixer would go really fast no matter what speed I put it on and it would shut off after five seconds. I came to the FixYa site and saw that one solution that seemed to work was to replace the Hall Effect sensor.  So I went to a local hardware store and purchased a new Hall Effect Sensor for about $13.  After I replaced the "defective" sensor, my mixer still did not work.  So, I started experimenting with the three prong orientation of the control board--this can make a big difference. After a little trial and error, I found the correct orientation for the sensor and my mixer worked good as new!  But I was curious to see if the improper orientation was the cause of my original "defective" sensor.  So I put the "defective" sensor back with the proper orientation and THIS ALSO FIXED MY SPEED PROBLEM! There was nothing wrong with my original Hall Effect Sensor at all--it simply was not snugly or properly seated!  I'm not sure how it happened--possibly over time the sensor prongs may have become unseated from the vibrations of running the mixer on high speeds--but my original Hall sensor was not seated properly or snugly.  So before you run out and buy a new Hall Effect sensor make sure that the original one is not only snugly seated but also properly oriented!  If I knew how to add digital pics, I would have put pictures in my comments to clearly demonstrate what I found.  Unfortunately, I am not sure how to do this.   To sum this up: 1. Download the parts information and diagrams from the Kitchenaid site and find the Hall sensor (part # 9703312).  2. Make sure that the Hall sensor is firmly attached on both ends.  The actual sensor should be located next to a tiny magnet and this end needs to be securely seated.  And the other end of the Hall effect sensor has three small prong holes which also need to be firmly and corrected seated to the control board! Bottom line, my mixer is working like new and I put the original Hall Effect sensor back in the mixer. I'm going to hold on the new one as a backup...you never know.
Posted on Dec 30, 2008
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
  • 16 Answers
SOURCE: kitchenaid mixer speed
I would recommend that you first check the Hall Effect sensor which determines the mixer’s speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My mixer worked as good as new! But I was curious to know if my original sensor was defective, so I put it back in mixer and again made sure all of the connections were snug and tight. Guess what?  My original sensor also made my mixer work!  There was nothing wrong with the original Hall Effect sensor except that the connection between the control board and sensor was not tight--unfortunately I didn't check the connection before I decided to buy another sensor. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations. To fix your problem:
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall Effect sensor looks like. BTW the part number is 9703312.
2.  You'll need a phillips head screwdriver to open up the mixer gear case cover.
3.  Make sure that the connection between the control board and sensor is absolutely tight and snug.
4.  Also, make sure that the orientation of the sensor is correct.  It's difficult to tell which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or down. After you've made the connection, run the mixer. If it still doesn't work, disconnect the sensor, reconnect it with the prongs facing the opposite direction and try it again.  I actually found the right sensor orientation through a little trial and error.  But by going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation.
5.  This whole process probably takes about 10-15 minutes to perform.
6.  Finally, use your common sense and make sure to unplug the mixer before checking, connecting or disconnecting anything.
My kitchenaid artisan mixer doesnt run fast enough
It may be seizing up the bush that your accessory drive runs in, if you can see grindings in the front by the square drive that is a sign. Here in NZ that bush is only available as part of that whole top cover/housing. The accessory drive gear will also need to be replaced.
Feb 17, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Mixer wont start
Check for broken wire under back cover. Check operation of switch contacts on black speed control plate. Check carbon brushed under black screw caps on the sides. The brushes are keyed, they only work one way.
Jan 08, 2014 | KitchenAid KSM150PS Artisan Series Stand...
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Hi, the motor went slower and slower and now has stopped. We were using the meat grinder and we have only used this machine 9 times in the past two years. We are very upset customers and have 15 pounds...
If you remove the meat grinder, does the mixer still work? It could be that the meat grinder is jammed.
You might have also blown a breaker. Have you tried plugging a lamp or something else into the outlet to make sure it's still working?
Oct 18, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My daughter's Kitchenaid Artisan 325 watt mixer had a malfunction last night. The unit itself is less than 3 years old. It had been running on high for approximately 5 minutes when sparks began to fly...
Sorry cant solve this but mine did the same. Mine is almost 4 years old now. Have you found out what the problem was with yours? Have you sent it back? Nicky.
Aug 02, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My Kitchen Aid KSM150PS Artisan red mixer trembles alot and makes a grinding sound when I use it. I've exchanged it once already and have the same problem again.
Kitchenaid mixer are supposed to make a slight grinding sound while operating under load. This is simply the gears meshing together while the motor is turning them, but if the sounds gets worse or is already a metal grind type sound this could indicate a broken worm gear inside the unit, and shouldn't be run any longer. However if your mixer isnt on SOLID ground this could cause the tremble as well.Hope this helps
Thanks
Oct 31, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer races when turned on
Hi. Get in touch with Kitchenaid Parts and order a new Control Board. If your mixer is still covered by warranty it's free. ricardok45
Dec 23, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Mixer stuck
It sounds like you burnt the motor out or shorted the speed control.
Dec 24, 2007 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
276 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
