HOW TO WIRE E3EB-20 TO PANEL BOX - Heating & Cooling
  • 2,113 Answers
I'm just assuming that is 220 volt 20 amp The wire that is run is likely a common romex 12-2 NMD-90 Strip the 2 wires put red tape on the white wire as it is no longer a neutral. Hook both wires into a double 20 amp breaker. Put the ground wire onto a ground screw.
Posted on Nov 28, 2013
Locate instrument panel fuse for Thunderbird 2002
Fuse number 20 in the passenger kick panel fuse box.The ORG/BLU wire goes directly to the instrument cluster.
Mar 13, 2014 | 2002 Ford Thunderbird
Dedicated 20 amp outlet
Ideally you should run the line straight from the circuit breaker out to your hot tub, but if the line running from your circuit breaker to the box you're using now is 20amp. you can absolutely connected to that. to be up to code it cannot be an open box it needs to be closed After you wire in your 70ft connection. (that's assuming the box that you're using is dedicated already to your hot tub) then the only difference would be is your using extra line and costing you tenths of a penny extra and electricity per hour.
Jul 27, 2013 | Electrical Supplies
Can I install a junction box before my water heater junction box?
Junction box is fine.
Must be accessible and not hidden inside wall.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-select-right-wire-nut.html
43 feet is not over 100 feet, so wire size can stay same.
Recommend 30 amp breaker and 10 gauge wire for 4500 watt water heater.
If circuit has 20 amp breaker and 12 gauge wire, recommend 3800 watt elements.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Mar 21, 2013 | Water Heaters
Nothing to hold filter
I have the same problem. Sometimes the filter has been on the floor in that large wooden box under the unit. I have bought filters that were too big and forced the door to shut them in so they don't move. Now if your clips are gone on the outside of the unit door you may have to use good old duck tape (the color of the door) and just tape it.
Aug 11, 2012 | Intertherm E3EB-017H Furnace 17Kw 2
How do u wire athermostat to the furnance and ac unit on model e3eb-015h nordyne
You need to get low voltage wire known as 5 wire. run wires thru wall to stat and furnace Red wire goes to R terminal white to W terminal Green to G terminal Yellow to Y terminal on both the stat and furnace circuit board. Now you need a wire called 2 wire low voltage wire run that from furnace circuit board to outside A/C. At furnace hook red wire to Y terminal and white to C terminal doesnt matter which ones you hook up at outside unit. Do it just like i told you this will work properly.
If this helps please rate me.
May 20, 2011 | Heating & Cooling
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
F 450 instrument cluster has no power and is inop need to trace wires to power source
Interior fuse box fuse no.33(15amp) supplies power in run/acc postion to BK/PK wire pin 19 of cluster.
Interior fuse box fuse no. 45(10 amp) supplies power in the start or run postion on the RD/YE wire pin 20 of cluster.
Interior fuse panel fuse no. 41(10amp) supplies power to the battery saver relay on LG/OG wire pin 11.
Interior fuse panel fuse no. 35(10amp) supplies power to interior lamp relay on BK/LG wire pin 12.
The last 2 are hot at all times.
Apr 11, 2009 | 2004 Ford Super Duty F 450
Fan Only Won't Work
I jumped the rc and rh wires in the therostat box and now have fan only when selected.
Jul 01, 2008 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
