Question about Hand Tools
Motor burned out
Dremel VS Moto Tool 370-5
    Genius:
  • Hand Tools Master
  • 1,198 Answers
I got a good one on e-bay, now I have lots of bits!
Posted on Nov 28, 2013
2 Suggested Answers
  • 194 Answers
SOURCE: change sandpaper head on dremel motor tool
if your talking about the barrel sander there is a screw on top that you loosen and the barrel will slide off put the new one on tighten screw and your good to go
Posted on Feb 20, 2010
Dremel VS Moto Tool #370-5
Are you sure? Have you checked the brushes?
Nov 28, 2013 | Tools & Hardware - Others
How do I change the drill tips on the Dremel 370 6 model? Can't find the instructions. Thanks
There should be a shaft lock button near the tip end of the tool and you need a small spanner wrench (included with the tool) that inserts into the collet sleeve hole and is turned CCW (looking at the tool end) to loosen the collet itself. Tap on the tool end lightly to help loosen the bit. Hope this helps!
Nov 07, 2010 | Dremel Garden
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
My Dremel tool motor still works but shaft won't turn?
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
Dec 06, 2009 | Dremel Variable - Speed Multipro Rotary...
No operation
Hello their, thanks for trying fixya, the issue with these type of tools is normally the ac motor, their are many diffident types used but yours in particular 120V, 50-60 Hz, AC, 1.15 amp double insulated motor. Operates from 5,000 to 30,000 RP, their is a electric motor that may have failed on you or the switch could burned out. this is possible when the contacts are shorted for to long become to hot and overload the small circuit used to control potential voltages to the motor, consider it like a variable pot switch.
a simple test here would be you can take the unit apart easily enough and unplug from wall, make sure you have no voltage from mains going in. when the unit is not plugged in get your trusty voltage ohm meter or vom
Nov 27, 2009 | Dremel Tools & Hardware - Others
Broken flex shaft on Dremel model 232 broke
You can go to Dremel.com and find assistance or call their toll free number at 1-800-437-3635 and speak with their tech assistance. Let me know if you still need more help. Also I tried using the model number provided and it came up empty that is why I am directing you to this site yourself.
Feb 15, 2009 | Dremel Variable - Speed Multipro Rotary...
Hand Tools Logo
60 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
