Rca tv troubleshooting
Scrible picture when i turn it on till it warms up 61inch projection tv rca model no.d61w130
  • 3 Answers
The CRT focus caps need change all 3
Posted on Dec 29, 2013
4 Suggested Answers
  • 1694 Answers
SOURCE: no sound or picture
jerel,
Please provide accurate info for best solution = on back of set =
Model # , service # , chassis # , Mo / Yr built............
Stopped playing = Dead ? ....no sound , no picture, no green
power led on front??...........................Help ! Let me know..T.
Posted on Dec 03, 2007
Mr Alexx Sir
  • 12 Answers
SOURCE: TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Posted on Jul 29, 2008
SD Tech
  • 14553 Answers
SOURCE: TOSHIBA 57H82 TV Blurry for 15 minutes till warms up
This is a model first sold 2002.
They have a history of the Hyper board failing. Usually noise or lines in the picture and the warmup time gradually gets longer and longer.
This board processes all signal from all inputs inside the set and is no longer available from Toshiba.
The only way to get one is from a national company called PTS Electronics who rebuilds or repairs them--cost for rebuilt board is about 220 plus shipping and part number for this model is:
Part Number23148024
I have a service bulletin with photos of the board on my computer.
It is a financial decision, not a job for the average do it yourself person to attempt.
Let me know if you have questions or need help.
SD TECH
Posted on May 03, 2010
Rca scenium 61 inch dlp
This unit has a bad colorwheel
Jan 12, 2009 | Televison & Video
RCA Scenium d61w130 turns off then on
I installed a small cooling fan in the back ot the TV. It was overheating. Fixed the problem.
Nov 22, 2008 | RCA D61W130 61" Rear Projection Television
Rca scenium turns off and on
I had the same problem with mine. It was overheating. I installed a small cpu cooling fan on the back of the unit. No problems since. Good luck.
Mark
Nov 08, 2008 | RCA D61W130 61" Rear Projection Television
Tv turns off after a few minutes
I had the same problem with my D61W130. It would turn off and on intermittently. Called a TV repair shop and they said this model was known for it's poor soldering connections on the power board. They came out and took it apart and re-soldered the board. It cost me almost $300 bucks but it seems to have taken care of the problem. It's working great now.
Oct 31, 2008 | RCA D61W130 61" Rear Projection Television
RCA will not turn on
replace the flyback. you can get a replacement at the following link with free tech support to expain step by step how to replace it. you need flyback 259296 Heres the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W130 tv
this unit has two tuner modules. one is the main tuner and the other is the slave or the pip tuner. it would apear from your description that the main tuner has failed. it is possible that this can be replaced.
Jan 28, 2008 | RCA D61W130 61" Rear Projection Television
My TV turns off then turns it self back on 3-5 minutes later. We are told it is the small signal board?
rca? d61w130 itc222 ..does the unit flash green led.
itc222 shut down if the processor detects a problem. can be many different things. horizontal output is first thing to check. any sounds, chirps, smell... did it ever work
Dec 19, 2007 | RCA D61W130 61" Rear Projection Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
